Speed Inc 1579 HP Vid added
Old 03-08-2012, 11:13 AM
427's Avatar
When you hear the engine free like that with very low load it will normally show the power dropping as the run goes longer and the rpm will look like it's straight line. If you are using the C6 pump drive 1.250 input I have a converter that would let you up the boost that you are welcome to try. It would let Jim explore the 4bar without cooking the trans fluid!!
Kurt
Originally Posted by LASTLS1
Converter doesn't seem loose. I'm not sure on the converter or rpm. I didn't change anything with the engine so Jim was just rebuilding the VE table for the 4 bar. We didn't print out any dyno sheets.
Old 03-08-2012, 11:27 AM
6 Second Club Moderator
LASTLS1's Avatar
Kurt
I think the run sounded funny because about 6800 rpm the boost controller shut off and went to base boost, 11. This converter is much tighter than the one I ran in Indy. The shift light didn't turn off between shifts! I hope it's not too loose. I'll call you in a minute.
Old 03-08-2012, 11:39 AM
Z8'S's Avatar
Very nice!!! Speed Inc. builds some nice stuff.Give em hell in Florida Andy!!
Old 03-08-2012, 11:45 AM
chasgiv3's Avatar
BEAST! Nice! Wish I had time to travel out there to lend a hand. Good Luck!
BTW Andy you almost got me thrown off the track at Byron. I ran a 9.1 then you ran after me and you ran solid 7's. Then they went looking for the car and since ours look pretty close they thought I was you. We ratted you out and had them go check out your ride at your trailer. LOL..... I knew you were legal for that number so I figured you wouldn't mind.
I'll tell you after watching you run that day I really thought hard about swapping my turbos for the 76's. But like you said chasing the numbers is a never ending process....best of luck!
Old 03-08-2012, 12:57 PM
LASTLS1's Avatar
Thanks,
I have been thrown out of there. The first time I went with the street driven set up that went 8.2's they didn't like. LOL No fire suit, no gloves, no lic, 10 point cage, no shut off ect.....
I'm all legal now, it's easier.
Old 03-08-2012, 02:01 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,159 Likes on 753 Posts
Intmd8 (Jim) did a great job tuning on the car, it never skipped a beat last year at the big races and Andy would have had a better shot in the finals at Indy if the converter wasn't having problems.
Let's just try to avoid having fries with every meal next week haha.
Old 03-08-2012, 02:35 PM
koolrayz's Avatar
Good luck down south Andy
Old 03-08-2012, 02:49 PM
LASTLS1's Avatar
Thanks Ray I'll need it!!!
Old 03-08-2012, 02:51 PM
LASTLS1's Avatar
Our last meal was good.
Old 03-08-2012, 03:47 PM
qqwqeqwrqwqtq's Avatar
Where did the power peak at? Sounds like the converter is loose, higher boost may not help. What input is your converter?
Kurt
On the dyno, hitting 200mph at 8300, or about 6% converter slip.
Does sound weird on the vid since the boost controller dropped out and it went from 28psi to 11psi boost.
It was picking up consistent power vs boost up to that point, should be interesting to see how it does at the track
Old 03-08-2012, 05:42 PM
koolrayz's Avatar
That 6% slip was after the boost fell back to #11? that slip will be a lot higher when it is back up to full boost.
Old 03-08-2012, 06:20 PM
  #32
LOL, you don't say. I calculated it off of the previous dyno run, close to 1500rwhp and steady boost to 200mph/8300rpm.
Obviously it will be different going through the traps but on the dyno it doesn't seem excessive.
Old 03-08-2012, 07:35 PM
  #33
427
427's Avatar
6% at that power sounds really good. It sounded like 25% on the vid at 65-7000, that was the part I was questioning. I have a converter that might help that he is welcome to try. I tried calling but could not get through on the number he left. I will be pulling for you in Florida, good luck!
Kurt
Old 03-08-2012, 07:46 PM
  #34
7 Second Club
BlwnTA's Avatar
Very cool Andy, sounds good and you should be very competitive...hope see you down there...still finishing things up but I might make it, should know by Sunday for sure.
Mark
Old 03-08-2012, 08:08 PM
  #35
LASTLS1's Avatar
Mark
Sounds good. Somebody told me you got it up and running. I hope you guys make it, should be a fun time! I hope my trailer comes in, they said by Monday at the latest. Cutting it a little close. lol
Old 03-08-2012, 08:28 PM
  #36
LASTLS1's Avatar
Kurt
Thanks Kurt!
Old 03-08-2012, 11:50 PM
  #37
LS1Tech Premium Sponsor
ssvert99's Avatar
Looking great Andy! Now we just have to keep getting all that to the ground
Old 03-09-2012, 08:17 AM
  #38
LASTLS1's Avatar
[QUOTE=ssvert99;16061068]Looking great Andy! Now we just have to keep getting all that to the ground[/QUOTE
I have faith in you!
Old 03-09-2012, 08:31 AM
  #39
ZTwentyAteU's Avatar
Nice numbers!
sounds like a boost controller problem. Does the controller have a RPM setting?
Old 03-09-2012, 07:26 PM
  #40
LASTLS1's Avatar
Originally Posted by ZTwentyAteU
Nice numbers!
No rpm, just timed. I just ran it off of one stage for the dyno.
Quick Reply: Speed Inc 1579 HP Vid added
