Speed Inc 1579 HP Vid added
6 Second Club Moderator
I took the car to Speed Inc today. We are heading to FL for the LSx race next week. I had to switch from a 3 bar map sensor to a 4 bar to get over 29 lbs of boost. These guys are getting crazy to keep up with!!!! lol So Jim had to rework the entire VE table. ![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
We were having boost controller issues, we were going from commanded boost to base boost and back to commanded.
Something electrical is going on, I will check it out tomorrow. We kept it on the safe side because of the boost issue @ 11.2-1. It made 1585 rwhp @ 27 or 28 lbs of boost, boost went down to 11 lbs after 6800 rpm. We wern't looking for numbers just getting the VE table close and we'll finish it in FL at the track. At least I can turn it up now past 29 lbs to run with these nuts!
FL should be fun!!!! Thanks again Jim, he was sick as a dog and stuck it out.![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
427, twin pt 76's, Speed Inc fabbed headers and turbo kit, soild roller, sheet metal, coil over, wet sump.
so almost 1600 hp and your "ironing it out still". haha that is just awesome and makes me jealous. good luck down in florida, speed inc did my car and it ran awesome, I can't imagine how your car runs
Yes it's a new converter. We just ran out of time, we could have turned it up but we got what we needed to done. Also the boost controller was acting up. The rest can be done at the track.
Converter doesn't seem loose, it's a new PTC. I'm not sure on the converter or rpm. I didn't change anything with the engine so Jim was just rebuilding the VE table for the 4 bar. We didn't print out any dyno sheets.
