down pipe size question
Old Mar 8, 2012 | 09:05 PM
jfg455's Avatar
Default down pipe size question
I am running a 5.3L +.030 forged pistons, H beam rods, LS9 cam, 317 heads. 8.2:1 comp. I am running a Turbonetics T76 Q trim, BB center, .96A/R. 1 3/4" primary headers into 2.5" hot side merged into 3" before the turbo. 12x24 plate and bar intercooler w/ 3" cold side piping. it will be a pump gas w/meth inj set up. I want to run in the 18-22 psi range.
Question: Am I going to run into an issue with back pressure with a 3" down pipe or should I step up to a 3.5" pipe? I have made the set up so a 3.5 will BARELY fit in and all the way out. Thanks in advance. G
Old Mar 9, 2012 | 07:20 AM
smokinHawk's Avatar
3" will be fine for the T76, though 3.5 will be better.
Old Mar 9, 2012 | 10:00 AM
patriotformula's Avatar
With those boost levels, I would run a 3.5" personally. The bigger you can go the better, and if you can help yourself keep the back pressure down at those PSI, it will help with your IATs.
Old Mar 12, 2012 | 01:29 PM
jfg455's Avatar
Thanks for the replies. Guess I will comence stuffing large pipe! wait, that came out wrong....
Old Mar 12, 2012 | 03:10 PM
gimmeluvin's Avatar
haha i forced my 4" pipe in.
Old Mar 13, 2012 | 05:48 PM
jfg455's Avatar
That is just wrong on sooo many levels! You tell people you got a 4" pipe?
3.5" it is. Thanks guys.
