when in boost-timing retard
Old Mar 10, 2012 | 10:13 PM
95batmobile's Avatar
Default when in boost-timing retard
as soon as i hit 3k the timing gets retarded so much that it almost stops the car from accelerating... I just got everything finished with the kit a guy has a little tune on it but i have not read of any sts kits getting a timing retard as soon as boost hits....
any thought? i do run hotter plugs which will change eventually, but this still does not happen to too many people so im not sure whats up with it... im thinking about disconnecting the knock sensor and seeing what that does
Old Mar 10, 2012 | 11:55 PM
Fbodyjunkie06's Avatar
Go ahead, disconnect the knock sensor it won't make any difference...that along with your hotter plugs should make it the bomb!!!
Old Mar 11, 2012 | 06:19 AM
98Camarod's Avatar
get it tuned
Old Mar 11, 2012 | 10:23 AM
thats whay i said... i had like 6 people telling me it would be fine... i have always been told to keep it
Old Mar 11, 2012 | 01:53 PM
Ironmancan's Avatar
1st get your sarcasm detector fixed
Old Mar 11, 2012 | 02:07 PM
98Camarod's Avatar
I'm assuming his bomb was referring to your motor blowing up
Old Mar 11, 2012 | 04:10 PM
thanks for the help guys...
Old Mar 11, 2012 | 05:43 PM
itsslow98's Avatar
Get a damn tune its pretty simple.
Old Mar 11, 2012 | 06:14 PM
im getting a tune... im wondering why its retarding the timing when all the other turbo cars dont have a problem
Old Mar 11, 2012 | 06:26 PM
jtotheizzo's Avatar
The problem is you are not giving us enough information to go off of. The info you are giving doesnt bode well for you. A quick answer to your "why this car" question is that every car is different and will respond differently to boost. Everyoen is recommending tuning because they will do some data logging and at that time will be able to answer why you are getting timing retard. Good luck to you and bottom line is stay out ofo it until it gets tuned or it may in fact be "the bomb"
Old Mar 11, 2012 | 06:28 PM
see thats an easy way yo answer... glad some ls1techer can be cool
