Cogs... to be or not to be?
Can you guys give an update on where the ASP pullies stand? Good bad or indifferent. What do i need to know beofre ordering?
Mike
me and jeremy and tom have to cut open the bracket slot for the idler 1.25" up to make room to run the belt under the tensioner, you have the steel bracket so you don't have to worry about flexing....I am going to cut my aluminum bracket, I got a support so I don't think it will be a problem......I had to use 3 washers on each stand off, I need to take my idler pulley to sikora to have machined down to clear the stock idler pulley so they do not contact.......
Tom is tuning is car on wednesday so we will see where the boost will be here at sea level, I will be getting my car up and running again by the weekend hopefully......
Then it just needs dyno tuning after that........
How far have the cogs, 8-rib, and the 8-rib self tensioning pullies been taken? I'd perfer to get the setup that is gonna take me to 20+ psi eventually.
Mike
n. pl. pul·leys
1. A simple machine consisting essentially of a wheel with a grooved rim in which a pulled rope or chain can run to change the direction of the pull and thereby lift a load.
2. A wheel turned by or driving a belt.
n. pl. pul·leys
People spelling that word incorrectly is a pet peeve of PSJ from way back.
I've had the ASP 8 rib setup, with the tensioner maxed out I had no luck for more than a dyno pull....it would see 14psi and then nose dive........Jeremy had a similar problem w/his 6 rib stuff.....
The COG is much more heavy duty and I can see how it will work better.......
I still don't know how Scott does it, he tried to help guide me along w/my 8 rib dilemmas when I had them, but I never got anything solid out of the setup.........
n. pl. pul·leys
Wait and see the results of the dyno session though(Tom) Maybe he can post up any problems they had with them,
J
I found a source where I can use a fkywheel holder and a 250ftlb TQ wrench......gonna cut 3 threads off the crank bolt and only use one washer this time with red locktite, get that crank bolt tight, and use an impact to get it tighter, I want that sucker on there this time.....
Just waiting on the pins now............
We are also going to clear out my bracket with a big drill bit, I'm sure that will work the best unless we find other little goodies in the tool box.....
Tom
No luck on getting that pin kit jeremy, the guy disappeared off the planet
My blower now is making a new noise. It's got a higher pitched whine now. I thought it was low on oil, cause like most other ATI head units, mine weeps a little oil too. I changed the ATI oil, it lost a little but not much. The high pitched whine went away. Then came back after a few minutes. Found out it does it when the blower gets hot..
One thing all of us need to realize. once our car start to push this kind of power, issues will allways crop up. I drive my car all the time now, and my friends hear me complain about this or that. I have some other friends here in town with about the same power as me, with a Vortech T-Trim Blower LT1. I hear from him all the time how ATI this and ATI that, how ATI could have made this better, or they really did a F#$K job on this Clint. He always talks about how his T-Trim hardly ever causes him problems. The difference is, I drive my car 4 days out of the week. He hardly ever drives his, ever.
2 things I would like Lee at ASP to solve for me personaly. Make a Cogs setup with a Spring tentioner, and change the Aluminum Bracket to Steel, so it won't flex soo much. Also, I wish ATI made their bracket so you won't need to drop the blower every time to change your belt. With a 6rib I guess it was not soo much of a big deal. With Cogs, and dropping your blower all the time you break your belt, sucks. It's been 7 times now in 11,000 miles and 13 months. That's 1 time in every 6 weeks or so. It sucks..
I know there is a guy out there making a spring tentioner for ATI setups. I just dont want to spend the 600 right now.
All in All, COGS is worth it guys. Gotta find out a way to make it work. I'll take some pictures of my setup for you guys here soon to compare them.
Take care.
Clint
