Huron Speed + 1999 Z28 Build Thread
Yes, you will need a spacer to keep the sway bar. You don't need to keep the swaybar but IMO the car drives so much better. I used spacers from a body lift kit for a truck...
Did u have this issue with the stud on the manifold hitting the k member? I'm wondering if the poly mounts will make a diffence
Remove the stud from the truck manifold. Run to your local hardware store and grab a Stainless T-Nut in M10x1.5. Place the T-Nut in the bolt hole of the Crossover flange so the threads face up. I would put a tack weld on the T-Nut to the flange so it will not spin on you. Then simply thread in a M10x1.5 bolt from the top side, down through the manifold and into the T-Nut in the crossover pipe!
Jon
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I bought the CBR / Modular Turbo power steering lines because I kinked my stock lines. Not really needed but I wanted the peace of mind that my PS would work when I needed it to.
Take the green wire that is supposed to go to the A/C clutch and cut it off. If you do have A/C and wish to use this feature, by all means run it to the A/C compressor.
Take the Orange Power wire with the in-line fuse and tie the Black wire into it. Then run them to 12v power. I run these orange wires to the post on the fuse box. I also had some issues with the supplied 30a fuses. Switched to 40a fuses and never blew a fuse again.
Run the Red power wires to the Power wires (blue) on the fans. I like to use connectors here so you can easily remove the radiator/fan combo in the future should you have to and not have to cut wires.
Run the 2 yellow wires together into 1 wire, extend and run across to the passenger side by the battery. Here you will want to find the dark blue wire in the harness that runs over the shock tower. This is your PCM's trigger to turn the fans on (ground). You can tap into this blue wire, or cut and connect it to the PCM side as the other side goes to your own fan harness (unused). This is just a trigger wire so if you extend, 18awg will be fine.
The power wires from the fans connect to the red wires of the harness as mentioned above. Keep at least 12awg.
The ground wires from the fans run to a good chassis ground. Keep at least 12awg.
Jon
