Huron Speed + 1999 Z28 Build Thread
thanks for the tips, I'm sure they will be needed in the future once I up the boost
Considering the amount of available space the DP fits well. At first I was concerned with the space between the DP and starter so I wrapped the DP and put heat tape on the starter and I haven't had any issues. Not sure both / either are needed because the DP doesn't seem to get all that hot. A mini starter might give you more clearance but I would save the money for something else.
I'm using all stock lines and FPR but understand that I'm limited to around 550 rwhp due to the single racetronix fuel pump.
Maybe try dual Aeromotive Stealth 340lph. They are small and seem to really perform. i went with duall GSS340s this time around and recentley seen how well these Aeromotives performed. Pissed me off I didnt know better than to use these. They even out performed the Bosch.
I just mounted my ic and was wondering if i should leave it like that of zip tie to ic bracket?
I drilled holes into the i/c bracket and used push pins to secure the cover. I wanted to tuck it up as tight as possible to allow for the most airfolw to my radiator.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
