Huron Speed + 1999 Z28 Build Thread
Old Jun 12, 2012 | 09:19 AM
  #81
1999Black_Z28's Avatar
Originally Posted by 1999 SS
is there any work around to having the a/c deleted in order to run this kit?
Originally Posted by dammarler
nope, a/c has to go.
Yup, just like dammarler said, A/C has to go on any kit using a truck manifold on the passenger side. You can get around it by using a C6 manifold but then it wont bolt up with this kit or the stock k-member.
Old Jun 12, 2012 | 09:20 AM
  #82
things are looking great! we are basicly doing an identical build right now. my kit has fit perfect also. good progress man. here is a couple of mine
Sweet!
Originally Posted by LT1RAY
I love these kits! Makes me wanna sell my Vortech setup!
Do it!!!
Old Jun 12, 2012 | 04:59 PM
  #83
ls1wallen's Avatar
Maybe I missed it. What did you do with your front sway bar? You removing it or making spacers? Are you running the stock k member if so how are you going to drop the oil pan?
Old Jun 12, 2012 | 05:20 PM
  #84
I'm planning to make spacers for the front sway bar. I am running the stock k-member and will drop it a few inches to remove the oil pan.
Old Jun 12, 2012 | 05:35 PM
  #85
a-low's Avatar
I was planing to tap into the front cover for the return line but from your picture
it looks like the turbo sits kinda low for it to drain properly.
Old Jun 16, 2012 | 09:42 AM
  #86
dammarler's Avatar
the only way to tap the front cover is if you have an underdrive pulley. otherwise either side of the oil pan will work. i will be routing mine to the drivers side above drain plug.
Old Jun 16, 2012 | 01:11 PM
  #87
More progress this week. I coated the manifolds with high temp paint, installed my IAT sensor, installed my Derale fans (still need to be wired), re-wired my alternator (no pics), installed the BMR rad support, and drilled/tapped my oil pan.
For anyone debating drilling in the car or dropping the oil pan I highly recommend dropping the pan. I had it dropped, drilled, tapped, cleaned, and re-installed in less than 3 hours. It was very easy with everything out of the way and I dont know how else you could ever get all the shavings out. I left the shocks attached and slightly lowered the k-member and the pan came right out (just make sure you unhook the clips holding the brake lines to the k-member).
I have a 90 for the drain to enter the pan but I just installed this for now to keep the dust out of the pan.
Old Jun 17, 2012 | 11:54 PM
  #88
dammarler's Avatar
what size was the fitting you have and what size was the tap. i will be doing this this week. turbo is supposed to be here this week and this is pretty much my last step.
Old Jun 18, 2012 | 06:29 AM
  #89
The actual fiting is a 3/8 npt to -10an adapter and the tap is a 3/8 npt. You are better off ordering a complete drain kit from one of the sponsors (Modular Turbo, etc). They come with the all the correct fittings and the braided line.
Old Jun 18, 2012 | 09:15 AM
  #90
dammarler's Avatar
i ordered mine from modular turbo, just wasn't sure of the tap size. of course that's the one i'm missing... thanks
Old Jun 22, 2012 | 08:00 PM
  #91
Slow week...wrapped my crossover, wired my fans, and received my power steering line kit
Old Jun 23, 2012 | 10:40 PM
  #92
JetMech99's Avatar
Looking very good so far! I'd love to come check this thing out when it's done sometime if I ever head up your way, or if you're ever down south a little. I'm debating between this kit and the Kentucky kit. Subscribed!
Old Jun 24, 2012 | 07:13 AM
  #93
For sure, let me know anytime you are in the area and you can check it out. I do drive through Toledo once in awhile on my way to Cleveland but I'm always in a rental (b/c it's for work).
I don't think you can go wrong with either kit but the Huron Speed kit was more within my budget and I have been more than pleased with the fit and finish The stainless is also an added plus!
As of last night I am ready to start the final assembly phase and hope to have pictures up soon!
Old Jun 25, 2012 | 06:43 AM
  #94
A small tip for those using the Huron Speed or Spoolin Performance alternator relocation brakets - Replace the ribbed idler pulley with a smooth one and you will be less likely to shred belts. I used the one from the old alternator bracket.
I also installed my Modular Turbo power steering line kit. Very nice kit that takes the guesswork out of replacing your power steering lines and frees up a ton of room for the truck manifolds / crossover pipe.
Old Jun 25, 2012 | 08:58 AM
  #95
10secondZ's Avatar
I just bent mine outta the way a little, I wasnt aware and i was in a pinch, but it worked out great!
Old Jun 25, 2012 | 09:33 AM
  #96
Agreed, you can just bend the stock lines but I was trying to maximize the clearance and ended up going too far and put a small kink in one of the lines. Chances are it would have been fine but I would not have been happy with it...
Old Jun 25, 2012 | 10:01 AM
  #97
jrob56's Avatar
awesome build, in to see the rest of it.
Old Jun 26, 2012 | 07:15 AM
  #98
Getting close now!
Yesterday I had a local shop tig weld a bung in my downpipe for my wideband and when I got home I wrapped it with the DEI lava wrap I had left over from the crossover. A 50' x 2" roll was the perfect amount for the crossover and the downpipe!
I also measured and purchased a 72" belt which fit perfectly and I did the final install of the crossover, turbo, and downpipe. Sorry, no pics yet...
The main items I have to finish yet are:
-hook up the oil feed and drain to the turbo
-install the WG, BOV, cold pipes, and vacuum lines
-purchase and install air filter
-re-route PCV/catch can lines
-clean up the wiring / heat management
-cut and install the front bumper cover
Old Jun 26, 2012 | 08:26 AM
  #99
owentm3's Avatar
Looks great and clean. Good job. Ready to see some numbers. Lol. Im sure you are.
Old Jun 26, 2012 | 09:06 AM
  #100
Thanks! I'm definitely ready to fire this thing up!
