Huron Speed + 1999 Z28 Build Thread
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I bet your right...we've probably crossed paths before. Back when I worked for Magna I would cross the border a few times every month.
The results are already in:
https://ls1tech.com/forums/forced-in...sults-vid.html
I don't have mine installed yet but while I am spending time posting my progress there are at least 4 others who have the kit installed or nearly installed already. I have exchanged messages with 3 of them and each told me that everything fit together perfectly
In the meantime I installed a boost gauge, installed a tick master, continued working out some of the tuning bugs (the dreaded lean restarts with SD), and even made a few passes down the 1320 (no turbo of course
). With the LS6 cam, 317 truck heads, and stock exhaust the car ran 13.3 at 107mph. Not bad considering it only ran a 13.8 at 104mph stock.
http://www.youtube.com/watch?v=1AOvjH821d0
I am waiting on the builder to finish pouring the concrete approach for the barn so that I can move the Camaro into it and start making progress again. Until then I plan to just enjoy driving it...
Once both manifolds were fitting the rest was easy. The crossover fit perfectly so I installed and clocked the turbo. The next step was installing the Burkhart front bumper support and intercooler. After that I test fit the cold side pipes and once again everything fit great.
On Sunday I didn’t have much time but I sandblasted / painted the manifolds and installed my IAT sensor in the pipe feeding the throttle body. I placed the IAT under the fuse box to keep the high engine bay temps from heat soaking the sensor and causing issues on hot starts (lesson learned from my 2 Bar N/A tuning).
On to the pictures:
Crossover assembled outside the car:
A bunch of un-needed weight removed:
Crossover installed:
Test fitting turbo:
Burkhart bumper support:
Intercooler installed:
First cold pipe installed:
Rest of cold pipes installed:
Next steps include relocating the alternator and dropping the oil pan to install the drain fitting.
lmao. i used to work on the bridge a few years ago. ive probably seen ya before. (i was in a toll booth quite a bit)
