Huron Speed + 1999 Z28 Build Thread
Old Jun 28, 2012 | 03:52 AM
  #101
1999Black_Z28's Avatar
So close...just need to gap/install plugs, cut bumper cover, and hook up vacuum lines
Everything wrapped and downpipe installed
Test fiting blanket
Drain complete
Wastegate
BOV
Air Filter (AEM 21-2057DK) with fitting
Charge pipe
Old Jun 28, 2012 | 07:08 AM
  #102
RedRocketZ28's Avatar
Looking good man. Can't wait to see it running.
If you don't mind, can you share what you used for the fitting on the filter and how you went about it?
Old Jun 28, 2012 | 07:45 AM
  #103
jrob56's Avatar
Excuse the ignorance whats the air filter fitting for? Meth?
Old Jun 28, 2012 | 07:52 AM
  #104
Summit p/n SPE-5946. I drilled the top of the filter with a 9/16 drill bit and threaded the fitting in there. The rubber top is much thicker than I expected (around 1/2") and the fitting is very snug
It's for my dual catch can setup. I have a one way check valve to stop boost from entering the crankcase on one can and on the other you need a source of vacuum under boost...hence the fitting on the airfilter (see attached diagram)
Attached Thumbnails Huron Speed + 1999 Z28 Build Thread-turbo-catch-can-install.jpg
Old Jun 28, 2012 | 09:34 AM
  #105
Added a turndown to the downpipe. In the future I may add more exhaust but for now this will work
Old Jun 28, 2012 | 09:39 AM
  #106
Thanks man. I might have missed it in the thread so forgive me, but what catch can are you running? I was thinking of going with the Saikou Michi can.
Old Jun 28, 2012 | 09:43 AM
  #107
I'm running the Saikou Michi as well. It's not in the build thread b/c it was on the car when it was NA
Old Jul 1, 2012 | 10:21 AM
  #108
JetMech99's Avatar
Where do you plan on having the tune done?
Old Jul 1, 2012 | 11:11 AM
  #109
I'm tuning it myself with hptuners
Old Jul 1, 2012 | 07:45 PM
  #110
kylemm1002's Avatar
Just read through your build! Can't wait to see the final build and see the vids!
Old Jul 4, 2012 | 06:08 PM
  #111
Pretty much done except for the tuning! Over the past few days I hooked up the wastegate, the BOV, and the catch can. Once that was done I went over everything to make sure all the connections were good and bolts were tight and the final thing I did was cut the bumper cover for airflow to the I/C. Today I installed the bumper cover, put the front tires on, and fired it up for the first time. Video's to follow...
In the meantime, here are the pictures of my progress:
Old Jul 4, 2012 | 06:29 PM
  #112
Superman09's Avatar
LS1Tech Sponsor
In for the vids!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jul 4, 2012 | 08:31 PM
  #113
Old Jul 5, 2012 | 08:47 AM
  #114
Superman09's Avatar
LS1Tech Sponsor
__________________
Old Jul 5, 2012 | 06:09 PM
  #115
fastcars95's Avatar
Everything looks nice and clean
I keep having setbacks with my set-up. I was supposed to be on the dyno tonight but I lost my clutch hydraulics.
I really want to see what these huron speed kits can do. Mine pulled like a SOB on 15lbs. It was almost too much.
Enjoy
Old Jul 5, 2012 | 06:49 PM
  #116
jsteele90's Avatar
badass build!! im jealous
Old Jul 5, 2012 | 09:11 PM
  #117
Stumbaugh's Avatar
Very sick build.
Old Jul 12, 2012 | 11:43 AM
  #118
JetMech99's Avatar
Any updates?
Old Jul 15, 2012 | 10:05 AM
  #119
Ryanbgb22's Avatar
What did you do for where the charge pipe comes through the fuse box area? Just leave the fuse box loose?
Old Jul 15, 2012 | 10:29 AM
  #120
willizm's Avatar
My catch can setup is exactly the same down to the saiku michi cans you used. So far it's working well so you should have good luck. I had issues using a short filter like that when tuning for higher boost. No issues at 11 or less psi, but when going higher my IAT's would rise and boost would taper badly. The filter was choking under the pressure and causing the turbo to work really hard causing higher IAT's. I since put a larger element and also routed it down and away from the pluming. No issues so far. Keep that in mind if you experience the same. Very nice build btw, looks very similar to mine.
