s475 inlet elbow suggestions
Thanks
I was thinking of just using something like this bottomed-out into the inlet housing, and using a 5" to 4" silicone transition hose to hold it in place.
http://www.ebay.com/itm/5-Cast-Alumi...177#vi-content
this is the one i have on my car
http://intakehoses.com/Merchant2/mer...gory_Code=CHEW
Do you think neckinging down the 5" inlet to a 4" inlet would cause any losses? I'm only looking to make apprx 12-14lbs of boost at full tilt. The inducer is only 75mm/2.95", so even 4" seems more than enough. Unless, there's somekind of flow pattern that I'm not considering.
Does that have a 5" inlet and outlet?
EDIT - yes it does, and I ordered that yesterday!!!!
