Methanol pre-blower results
Does anyone have results from same day testing with meth using a nozzle before the blower? IAT temps with and without meth on.
Thanks
I know the blower itself gets hot enough wrinkle the paint on it. I have watched mine melt a bag of ice in no time. So to run the meth through the blower will definately help. Get it hooked up and let is know how it works.
If it's in front of the TB you should be fine. I'd still say for better cooling though, and given how hot the air can get that using 50/50 water/meth will be better. The water will continue cooling long after the methanol has evaporated
How much power were you able to pick up when adding meth? How much did the IAT's drop? How much additional timing were you able to add?
