bed mount turbo with tonneau cover?
Old Mar 23, 2012 | 05:43 PM
T76s10's Avatar
Default bed mount turbo with tonneau cover?
i am currently doing a turbo 5.3 s10 with the turbo in the bed. i plan on using a tonneau cover because i dont feel safe with thousands of dollars laying in the bed for people to see. do you think the turbo would be fine with the intake under the tonneau cover? or would it starve the turbo for air? i was going to run the turbo intake under the bed but the turbo might be too close to the end of the bed to fit a 4" intake pipe. i dont want to finish welding it all up before its too late
Old Mar 24, 2012 | 09:29 AM
T76s10's Avatar
Anyone have any opinions?
Old Mar 24, 2012 | 09:44 AM
runsfromdacops's Avatar
If your worried about it just drill some holes next to the air fillter.
Old Mar 24, 2012 | 10:00 AM
T76s10's Avatar
do you think that would provide enough airflow to to turbo? i dont plan on using the tonneau cover for anything other than parking anyway but i dont want anything to go wrong just in case. but thats the other option i was thinking
Old Mar 24, 2012 | 10:12 AM
JRENIGAR's Avatar
Why not just build it with the turbo under the bed? This would keep the turbo much cooler and supply it with all the air it needs. There is good ground clearence under there right?
Old Mar 24, 2012 | 10:23 AM
lbfd48's Avatar
If your worried about it just drill some holes next to the air filter.
I also agree, some holes around the filter should do it.
Old Mar 24, 2012 | 11:40 AM
Syclone538's Avatar
I'm thinking it depends on how big of a hole you cut for your intake and exhaust to go through the bed.
But I'm wondering why anyway, as the syclone typhoon guys never had any problem fitting a ls and 1 or 2 turbos under the hood.
Old Mar 24, 2012 | 11:44 AM
KILLER-LS1's Avatar
you'll be fine even with the tonneau cover closed. Ive camped in the back of a truck with the cover closed, and it is still pretty drafty in there. it might get hot in there though
Old Mar 24, 2012 | 12:17 PM
deeloc1's Avatar
Gonna do the sam thing to my El camino! My turbo is going in the bed. I'm thinking about putting som vents on the side of my car so the turbo can breath. I'm thinking I might not even run a filter if the vents are on the sides since there's less of a chance of the turbo sucking in debre or rocks likee a turbo being mounted in the front bumper or grill without a filter. Check out these pics!
http://www.bridgeracing.com/marshall2010turbofoxl10.jpg
http://www.bridgeracing.com/marshall2010turbofoxn10.jpg
http://www.bridgeracing.com/marshall2010turbofoxr10.jpg
http://www.bridgeracing.com/marshall2010turbofoxm10.jpg
I plan on borrowing a lot of things from this fox set-up except my turbo and intercooler will be in the bed!
This nova in post #83 hand a cool set-up for his rear mounted turbos too!
http://www.yellowbullet.com/forum/sh...=113879&page=6
Old Mar 24, 2012 | 03:12 PM
T76s10's Avatar
Thanks for the input guys. My original plan was to do a front mount but after welding it all up I absolutely had no room for a downpipe cause my crossover was under the bellhousing so I didn't have a path for a downpipe. I chose the bed because I wouldn't want water getting to the turbo just incase I was in rain even though I don't think it would matter and because of the show factor basically. All my pipes will be heat wrapped and ill have a turbo blanket to keep heat in to keep velocity going so I would have less lag with the rear mount. I might not even run a filter now that deeloc. But now ill have more piece of mind after getting all your input.
Old Mar 24, 2012 | 03:28 PM
Striker289's Avatar
on powerblocks trucks! they did a bed mounted turbo in a tool box.
Old Mar 24, 2012 | 05:53 PM
T76s10's Avatar
Thats bad ***! Did they have any sort of ventilation in the tool box?
Old Mar 24, 2012 | 09:57 PM
GhostofKrypton's Avatar
Get a retractable bed cover. That way when you are driving, you can have it open, and if you want to park it some where then you can close it up. They aren't badly priced, and you will have the best of both worlds. With the heat of that turbo, you will want some type of ventilation
