What size oil restrictor for 76mm journal bearing turbo
I bought a turbo oil kit that I have installed on my 76mm turbo (stock ls1). The flange that bolts onto the turbo for the oil supply (4an) is only sized with a tiny hole. The part description says something along the lines of 'reduced size to avoid over oiling'. How do I know if this is going to be enough oil, the hole is pretty tiny.
buy a .080 or .060
you can get t4 oil feed flanges with a 4an fitting with it predrilled and restricted for like 5-11 dollars on ebay and amazon.
http://www.amazon.com/Turbo-Feed-Ada...2771995&sr=8-2
buy a .080 or .060
Like he said a journal bearing turbo does not require an oil restrictor. Make sure your oil drain is as straight as possible I run a -10 to the oil pain no restictor and have no issues on my 76.
Some turbo's need restrictions or they can smoke at idle. You need to contact the people that produce the center of your turbo if it's a hybrid and they can give you the spec. My Garrett that has over 100,000 miles on it uses a .060 hole to maintain the oil pressure at the turbo of between 9-40 psi. Mine actually goes a touch over 40 psi at 5000rpm and up, but it does not smoke or have any problems. My engine without restriction would smoke at idle with a -4 feed, it was 60 psi at the turbo.
Kurt
Kurt
u don't need a restrictor unless you are above 80psi oil pressure wot. you can call garrett or turbonetics, many turbo vendors and I think the next size down on restrictor, I know it doesn't change a lot
