Turbo headers that fit Accessory drives?
Old Mar 26, 2012 | 07:57 PM
John510's Avatar
Default Turbo headers that fit Accessory drives?
I have been searching forever and can't seem to find what I am looking for. All of the pics I find with headers mocked up don't have accessory drives on them.
Car is a 68 camaro and it is a LS3. Has a Wegner front accessory drive with Vintage air and carbon fiber valve covers that are a couple inches taller than stock.
Curious if anyone knows which off the shelf turbo header (Stainless works, Virginia Speed, etc.) will fit my application or if I am better off having some made?
If it helps at all here is a picture of what Im working with......
Old Mar 26, 2012 | 08:09 PM
LS1NOVA's Avatar
Id go for a custom set on that setup. Stainless Works or the OBX up and forward style may fit but a custom set would allow you to get a little more clearance for the coils and valve covers.
What are the plans for turbo(s) and power goals?
Old Mar 26, 2012 | 08:19 PM
John510's Avatar
Was going to run 2 57mm. Id be happy with 500-550 at the wheels(assuming I can do that on a stock bottom end).
Not really looking for anything too crazy.
Old Mar 26, 2012 | 08:24 PM
LS1NOVA's Avatar
For 500 at the wheels you'd be much better off with some ported heads and a cam. It looks to be a pro-touring type car and the turbos are going to add a lot of heat, weight, and complexity. If it sees a road course, not a good combo. If its mostly for looks, then go for it. Looks very nice from what I can see.
Old Mar 26, 2012 | 08:52 PM
John510's Avatar
Its mainly a show car. The turbo kit would set it apart from everyone running a bolt on blower. If I can handle more than 500 at the wheels then that would be good. Just don't want to be on eggshells every time I punch it if the boost is too high since block is stock. I don't really plan on road coursing it. Just a weekend driver. It actually has a TSP231/236 cam with PRC valve train but that will need to be replaced with a different cam once turbo goes on. Heres a side pic
Old Mar 26, 2012 | 09:03 PM
LS1NOVA's Avatar
Killer car. Its not a max effort turbo setup so just leave the cam. It will have a nice lope and a whistle. The two best sounds in a hot rod. The LS3 has pretty high compression so I think you'll be pretty limited on boost but it should make nice power. Make sure you use an intercooler of some sort. Treadstone has a nice compact unit for twin lower inlets.
Old Mar 27, 2012 | 01:04 AM
ryle's Avatar
That is a sweet looking ride ya got there!!
As far as headers go, I am not sure where you are located, but I just had a set of custom headers built by a local guy and his work is top notch! I could not be happier with the work and his prices are some of the best there are.
Here is what he did for me:
https://ls1tech.com/forums/forced-in...-keeps-ac.html
And here is a kit he did for a '68 Nova:
https://ls1tech.com/forums/forced-in...ubes-pics.html
Old Mar 27, 2012 | 09:19 AM
Tiago's Avatar
where can I find this accessory drive ? got a link?
Old Mar 27, 2012 | 12:42 PM
John510's Avatar
It is a Wegner motorsports.
http://s41657.storefront-solutions.c...?CategoryID=38
Old Mar 28, 2012 | 07:05 AM
StainlessWorks's Avatar
Hey John
I can't guarantee fitment but it looks like we just might clear that setup.
Attached Thumbnails Turbo headers that fit Accessory drives?-69-2.jpg   Turbo headers that fit Accessory drives?-69camaroalstonchassislsxt.jpg   Turbo headers that fit Accessory drives?-img_0547.jpg
