what oil pump and timing chain are people using for turbo set up.
Old 03-30-2012, 07:40 PM
Sweet_SS's Avatar
Stock pump and Katech chain
Old 03-30-2012, 08:53 PM
NemeSS's Avatar
Self ported stock lq4 pump. .060 shim. Cloyes double roller.same thing i use for just bout everything. Srlf ported,shimmed stock ls.pumps. Even the summit double rollers work very well
Old 03-31-2012, 06:39 AM
red281gt's Avatar
I'm ordering the katech c5r today
Old 03-31-2012, 08:10 AM
lt1773's Avatar
Melling 10296 & Rollmaster double
you will need either :
grind the pump & Timing cover OR just add Two double timing cover gaskets
Old 03-31-2012, 01:51 PM
I8UR4RD's Avatar
Melling and JP Performance billet double roller.
Old 03-31-2012, 03:03 PM
Oh4GTO's Avatar
Melling/Katech
Old 03-31-2012, 11:18 PM
Texhotrod593's Avatar
Lingenfelter high volume pump and a ls2 chain here
Old 04-01-2012, 08:16 AM
Adam86's Avatar
Melling pump and LS2 chain. 60psi of oil pressure at idle startup and 45-50 once warm.
Quick Reply: what oil pump and timing chain are people using for turbo set up.
