Why #7?
Old Apr 11, 2012 | 07:06 PM
  #141
gectek's Avatar
Originally Posted by miatainthe10s
I would like to see some of the big boy chime in. Like someone who builds these things day in day out. Maybe va speed or Texas.It seems funny that they haven't yet. Or there just laughing cause it just in the tune.
You do realize that Kurt in this thread is Kurt Urban right? Maybe you do not know who all the big boys are.
Old Apr 11, 2012 | 07:18 PM
  #142
lsxmalibu's Avatar
i dont believe its the water temp, i have a temp gauge on the front and rear , rear is 10-15 degrees hotter, after a run my rear temp is around 180, i also run a shimed wide open thermostat to keep engine cool
I run a dedicated line fron the rear steam ports and tapped into the suction side of the waterpump, hoping it draws the water from the ports. my motor is untuned, just good a/f and locked out timing, I ran a 6.0 for a year and 5.3 for 2 years and no problems.
Old Apr 11, 2012 | 07:27 PM
  #143
miatainthe10s's Avatar
I had to have missed it. I'm one a phone.
Another thought, are the guys with the newer block with the piston oilers have the same #7 issue?
Old Apr 11, 2012 | 07:30 PM
  #144
gectek's Avatar
Not really, but the piston oilers help keep ALOT of temp out of the cyls too.
They started using the piston oilers in 2005 with the GM 3.5l engine. They only installed it on one set of cyls though, #s 5 and 6. No others. It helped the problems with those cyls though. And they are the cyls that are fed first with air and fuel and have the T stat right by them.
Old Apr 12, 2012 | 08:01 PM
  #145
I8UR4RD's Avatar
At 9 lbs you doubtfully need the meth or e 85 honestly unless you run over 10.5 compression and a helluva lot of timing.
Exhaust happens in pulses, a clothes dryer does not pulse the air....unless you drive a Cube, in which case it looks like a Maytag anyway.
haha...true that about the cube...yeah i know all about the exhaust going off in pulses as each individual cylinder fires etc....thats basic ****....i was just saying...when any exhaust is restrictive....it causes hotter temps.
as far as the meth....i think I def needed it even at 9lbs.....i started at 9 lbs...now I am going to max it out( anything that cools is a good thing)
.....at 9:6:1 and I will be using e85 and meth since I already have the kit. I dont mind a bit of overkill. I will be running steam ports if at all possible. I think it may depend on the heads. I read a few pages back that some aftermarket heads do not have the ports on them even. that would be scary.
yeah the exhaust would not be the key as I said, because there are true dual guys and dumped exhausts....I was just saying I was thinking about this some time ago and it crossed my mind....the issue is simply too much heat. somehow, we gotta get the temps in that cylinder down and as always avoid detonation at all costs. It would be nice to come up with a real solution though.
Old Apr 12, 2012 | 08:10 PM
  #146
I8UR4RD's Avatar
Originally Posted by The Alchemist
Now if only the evans pump had a pulley hub on it like the ls2 does so I could use it with the Procharger.
i was thinking the same damn thing.
  #147
gectek's Avatar
^ I believe they were referring to some of the coolant passages not lining up right or being revised. Not the coolant ports at the top of the head.
Old May 18, 2012 | 06:01 PM
  #148
willizm's Avatar
I might not be pushin the power levels some of you guys are, but after reading threads like "the Alchemist" started on the number 7 failures I knew I wanted to help prolong the life of my motor. Here are a couple pics of how it looks with an ls6 intake. I had the intake removed to install the fittings and line then slid it back into place. Don't mind some of the clutter, still cleaning up a few things.
Kurt if you have any suggestions on my mounting let me know. There were no instructions so I'm just shooting from the hip. Also I'm having my brother build a bracket to hold the manifold as it's sort of just free floating right now.
Old May 18, 2012 | 06:04 PM
  #149
gectek's Avatar
May want to have the outlet tilted up at a slight angle to make it the highest point so air cannot be trapped at the back of the KUP manifold. I have installed one just like that on a 370 GTO and did the same thing.
I really like that kit.
Old May 18, 2012 | 06:13 PM
  #150
willizm's Avatar
I'll definitely take that into consideration when building the bracket.
Old May 18, 2012 | 06:39 PM
  #151
Hangman's Avatar
this may be considered a little redneck and isn't pretty like the kit but, I just cut the two ends off the rear of the ls1 tubes, bent them a little so the ls6 mani would fit and hose clamped a piece of heater hose inbetween the 2 rear ports. Its not boosted but ive been running like that for over 5 years and have used over 3k lbs of n2o making 600 rwhp with np.
Old May 18, 2012 | 07:18 PM
  #152
Venting all ports is great. But just thinking outside the box. How much block integrity would be comprised by drilling two holes in the side of the block near 7 h 8. Then welding some pipe bungs in and with a remote electric pump push cool water in there.
Just a though.
Old May 20, 2012 | 09:08 PM
  #153
evo462's Avatar
Kind of off topic, but I figured "what the hell, worth a shot" and picked up a 4 port steam vent setup from a 5.3L. For those of you that went with a setup like this on an LS6 manifold, did you just take a dremel and hollow out the "ridges" on the bottom of the intake manifold where the steam tubes run? The ridges are only a few millimeters - is that even enough to clear the tube or did you have to go into the bottom of the manifold a little bit?
Old May 20, 2012 | 10:34 PM
  #154
Ryans99ls1's Avatar
i just ground down the ribs
Old May 20, 2012 | 10:41 PM
  #155
edge04's Avatar
interesting. where are you running the front? i am only getting a temp from my rear pass head and I've been concerned as my guage saw 230 the other day in stop traffic, 82 and sunny. I do have the rears vented and tied to the front which goes to my rad.
Old May 21, 2012 | 05:58 AM
  #156
The Alchemist's Avatar
UNDER PRESSURE MOD
What if it's a flaw in the design of the coolant passages in the head that causes coolant to not flow well enough over #7 combustion chamber? If coolant doesn't flow over it, the coolant temperature isn't going to rise, so it'll appear as though your temps are fine.
I'm just asking the question because I've never cut apart a head or done any kind of coolant flow study, so it's simply a theory
Old May 21, 2012 | 06:22 AM
  #157
Then aftermarket heads should solve it correct? If its the heads?
Old May 21, 2012 | 06:43 AM
  #158
Is the failure on #7 in the same side of the piston, say back side toward the trans?
Old May 21, 2012 | 07:01 AM
  #159
UNDER PRESSURE MOD
Well, I have a set of the PI heads, and if anything, they closed off the water port that is in the back location which I've been told could lead to further issues.
Mine was in the 10-11 o'clock position of #7, so upper left quarter of the piston.
But as you can see, I cracked the liner/block in the lower left. I'm not sure what the significance to the location it is, since the theory is it's the rings getting too hot and the gap closes up, causing the rings to bind and that takes out the piston, and sometime the block as well.
Old May 21, 2012 | 07:12 AM
  #160
lsxmalibu's Avatar
no vents on the front.
