tahoe needs some help
Old Apr 14, 2012 | 06:58 PM
TURBHOE's Avatar
12 Second Truck Club
Default tahoe needs some help
ok here is the deal. i'm thinking about changing thing up in the tahoe. here is what i want to do. take the 5.3 out and stroke it and make it a 363. that a 4" stroke with a 3.8" bore. that would give me a lot of cyl wall for strength. this will be topped off with the current p/p'd ls6 heads i have and a nnbs intake mani and 90mm tb. the cam will stay 215/218 595/605 lsg i have now. then i want to remove the single and go twins on the factory flipped manifolds.
so the question is which turbo's. here are my goals i have set for it. on the street i want to maintain the current 10psi i cruise with every day already. now for track days my goal is 900-1000whp. (yes i know its a tahoe) the thing is, being that this thing is heavy i want them to spool rather fast. but i would like them to do it with out a **** ton of back pressure on the motor. I will be staying with a 3200 stall like i have now but will be going to a 4l80e with a 9.5" 14bolt.
from what i have figured and plotted it seems that a pair of 6265 turbonetics turbos would do this job. but i'm not sure how close to there limit i would be. the way i have been plotting is using the full pressure ratio but only half the flow. is this the correct way to do it? should i go with 6665? maybe a .82 A/R in a t4 housing?
thanks for the help if i have left any info out just ask i can post it up.
Old Apr 15, 2012 | 02:06 AM
93camaro_zzz's Avatar
Why do people care about the thick cylinder wall of a 5.3, when with a full forged motor, you would lift the heads off the block before anything else being damaged with the motor.
Just wondering.
Old Apr 15, 2012 | 05:57 PM
TURBHOE's Avatar
why do people always bitch about guys going with smaller displacement motors. not everybody wants a damn 402 or bigger motor.
Old Apr 15, 2012 | 11:17 PM
TurboS10's Avatar
Yes you cut the flow in half.
I don't think you'll like the spool on the billet 62 & 65mm turbine's and small cid for a DD.
In no particular order-
6262's
GT3788's
GT3582R
T61 ptrim w/.69 ar -cheapest
A 3.8 bore has ~ .115 per side more sealing area than a 4.030.
Old Apr 16, 2012 | 03:56 AM
stock48's Avatar
9 Second Truck Club
If it were me I'd just go with a 6.0L +.005'' with good rods and pistons. I'd much rather have the bore stroke, and rod ratio, 3.622 stroke and breathing benefits of the 4'' bore. That long small bore long stroke isn't going to do what you are hoping for for the tq. A 6.0L set up right makes decent tq. JMO
Old Apr 16, 2012 | 06:14 AM
BOBS99SS's Avatar
Captain Double Post
Op post some pics of your ride, you are from ohio arent you?
Old Apr 16, 2012 | 11:08 AM
TURBHOE's Avatar
nope i'm stationed in florida now moved from maryland about 2 years ago and maine before that. i bought it in maine. but here are some pics
in the beginning.
here it is being useful.
and here is how it sits today. its been turbochraged since 08 iirc
Old Apr 16, 2012 | 11:11 AM
TURBHOE's Avatar
here a couple vids too.
this one is my wifey running a super charged silvy. the guy was talking smack and my wife played dumb. it was kinda funny.
http://www.youtube.com/watch?v=RqHPJ...SIGSk2OYEAgMnq
this one is me. my baby girl was rooting me on in the back ground
http://www.youtube.com/watch?v=X8_St...CHdldULBUex-iX
Old Apr 16, 2012 | 11:13 AM
TURBHOE's Avatar
6262's
GT3788's
GT3582R
thats what i was trying to figure out is what turbine would be good for flow and yet spool quick with out causing hella back pressure.
Old Apr 16, 2012 | 11:25 AM
TURBHOE's Avatar
well, when it comes down to it. if i absolutly do not like it all i will need is pistons and a block. but for now this is what i wanna try out. i think it will work out better than what most think.
Old Apr 16, 2012 | 04:30 PM
stock48's Avatar
9 Second Truck Club
Only one way to find out.
Old Apr 16, 2012 | 06:24 PM
TURBHOE's Avatar
yes, i agree.
Old Apr 16, 2012 | 06:40 PM
xx_ED_xx's Avatar
I got some C4 we can fix it
Old Apr 17, 2012 | 07:56 PM
TURBHOE's Avatar
what does that even mean?
Old Apr 17, 2012 | 09:07 PM
TURBHOE's Avatar
did i do this right?
Attached Thumbnails tahoe needs some help-62-1.gif   tahoe needs some help-t61.jpg   tahoe needs some help-t66.jpg
