JY5.3+LS9cam+s475+22lbs of boost in a 88GT
#161
it was a yellow hunk of **** in someones yard before we go it lol
im upper macungie near allentown
#162
swapped to a cast larger s480 unit today, going to do some dyno testing and track racing this weekend weather permitting
car made 600rwhp before on 22lbs of boost and 16deg of timing and went 9.86 @ 140mph consistently
we will see how the bigger exhaust 80 does
#165
What rack are you using?
I'm thinking about deleting my Power Steering and run the truck manifolds I already have. Did you need to relocate the alternator or was it more of a weight reduction removing the alt/PS bracket?
Also, what size is your belt and where is your belt tensioner located?
#170
Can't wait to get mine running. Doing a L33 with a trick flow cam, eBay head studs, LS9 gaskets, holley high rise intake and 80lb injectors in a fox as well. Went with the VS Racing 80mm turbo and I am hoping for about 700rwhp. Still wonder if I should have gone with an s475 or 480 to meet my goal.
#171
with the earlier turbo, was 600rwhp at 22psi kind of low for that amount of boost? or was that because it was a 220k mile JY LS, or maybe the 22psi was because of some sort of restriction?
#173
yep, we have a cam for it, going to cam it and then redyno and take it out racing this summer
