Reducing compression, do it with heads or pistons?
Old May 24, 2012 | 07:10 PM
V-10 Killer's Avatar
Default Reducing compression, do it with heads or pistons?
I have a SDPC LS2 402 with Diamond -13 or -14cc (need to do some digging on that one) dished pistons, and ETP 245 heads with 59cc chambers. I'd like to drop the compression on this motor for a turbo build. I think both pieces would survive a turbo build individually if left in place. Which would be better to swap/rework to lower the compression? I figure to get where I want to be, I need to get another 14cc out of each cylinder. I prefer to keep the ET heads, so perhaps having them re-worked to 72ish cc's? Or, I see Diamond makes -28cc pistons.
I'd love to hear peoples preferences on this.
Old May 24, 2012 | 08:59 PM
Deezl SS's Avatar
I would rather do a simple head swap then break down an entire engine. I would sell your ETP 59cc heads and buy a set of ETP 72cc heads. Just my $.02.
Old May 24, 2012 | 10:56 PM
killernoodle's Avatar
+1 that is a great idea.
Old May 24, 2012 | 10:58 PM
westtexasbuff's Avatar
Or sell the ETPs and buy some 317s.
Old May 24, 2012 | 11:06 PM
wicked z28's Avatar
what would the compression be by just swapping to a 72cc head and having the 13-14cc valve reliefs.
Old May 24, 2012 | 11:13 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I'd start with talking to ETP about the heads, ask if they'd be comfortable modifying the heads to that extent or if they'd recommend swapping heads instead. Depending on the miles on the heads they might benefit from being worked again anyways.
If they recommend swapping, I'd weigh the price difference between losing money on yours and buying more vs new pistons with a rebalance. Depending on the mileage maybe you'd prefer a shortblock refresh anyways.
I don't know if you'd prefer to stay local or send it back to us, but whatever you decide we'd be more than happy to help you out with getting it where you want it to be if you go that route and would like us to.
How much power do you want to make? Boost level goals? You're talking about dropping the compression quite a bit. With Diamond pistons, I assume we also used Callies crank/rods at minimum, correct?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 24, 2012 | 11:14 PM
I don't have my calculator here, but I think he'd be going from about 11.1:1 down to 9.7ish
__________________
Old May 24, 2012 | 11:32 PM
KILLER-LS1's Avatar
most engine builders agree that compression is best changed through piston dome/dish. When you upen up the combustion chamber in the head, you lose some of the important "quench". Obviously heads are much easier to change though.
Im no expert, but this is what I've been told by multiple engine builders
Old May 24, 2012 | 11:43 PM
wicked z28's Avatar
what turbo brand etc. will you be running.
Old May 24, 2012 | 11:53 PM
I tried e-mailing ETP a few months back when I started tearing down the engine bay, but got no answer from them. I know the deck on these heads looks nice and thick, I think I'd rather stick with ETP's over 317's myself.
I've had the engine since '04 or early '05. Even though it spent a lot of time sitting for various problems, I think it's got enough runs/miles where I would prefer to tear it down anyway to check/replace the bearings before putting a turbo to it.
Here's the original thread from SDPC that I ordered/specced parts from:
https://ls1tech.com/forums/generatio...lock-sdpc.html
Says that it's an Eagle 4" forged crank, SCAT H-beam rods, and Diamond forged pistons.
I'm shooting for 750-800 tops (at least until I buy a different FMU someday) through the 4L80 with the GT91. Boost will have to stay capped at 15 psi. I'm looking at getting the compression down to about 10.0:1 so it still has plenty of off boost torque.
Old May 25, 2012 | 04:25 PM
wicked z28's Avatar
Are you going to fab your own truck manifold kit or purchase one.Is 10.0:1 the highest compression to run a turbo safely without a meth kit.
Old May 25, 2012 | 05:13 PM
WheelsUp84z's Avatar
compression isnt necessarily the limiting factor, so much as the fuel being used.
Old May 25, 2012 | 05:22 PM
wicked z28's Avatar
I just want to make sure im on the same boat as he is and trying to see if I should go the turbo route.My engine specs are almost identical as his but on a 408.I want to slap some 317 to get the compression down and a s91 turbo.
Old May 25, 2012 | 08:43 PM
I always love doing my own building, but this might be one of those projects that I have to concede is just too time consuming to fab myself since I don't own a welder. I'll be getting parts as the money is available, starting with the turbo. Then I'll go with a T6 manifold kit based on reviews/availabilty. I don't expect it to be completed til next fall, but every journey has to start somewhere, right?
Old May 25, 2012 | 09:14 PM
there is a guy who has a shearer fab kit and pro-mod 88 for $5k in the classifieds thats a steal considering the turbo kit is almost $4k and the turbo is $2.2k+
