dyno vid from sunday
Old Mar 29, 2004 | 09:26 PM
MIGHTYMOUSE's Avatar
Default dyno vid from sunday
ran the car friday night btw 11.14 at 128.60 on a 1.86 short time.. the 2 step didnt work (stinkin wire fell out of the switch) but i slipped the clutch out and was happy with the time, amazing how being able to shift properly picks you up over a half second
i was kicked off after that for no roll bar... but im working on that this week.
took it to the dyno, mostly for fun sunday. was my first chance to really dial in the gate pressure and set points on the controller as well as learn how to log with the dfi.
since the dyno's at turbotech the car has gone to 33 spline axles from the 30's and 3.42 gears from 3.73 also you see this time was run with the 27" hoosiers
first pull was as i ran it friday night with the 93 octane and then i mixed in some race gas to something around 100 octane. not trying to press my luck i stopped at 670rw. just wanted to put a little more umph under the hood for this comming weekends EFA race at MIR. anyways, for your viewing pleasure.
http://home.comcast.net/~deezuns/670dyno.wmv
im really having some fun with this thing... not that it was slow before but its a bit to handle on the street for sure. i'll get back to running pump gas in a bit, for now the bests are 11.14 and 130.25 on 93 octane only
Old Mar 29, 2004 | 10:27 PM
2FAST4U's Avatar
Nice glade to see it running so good! BTW that is with the DFI right!
Old Mar 30, 2004 | 06:58 AM
smokinHawk's Avatar
would you get into the tens already
Old Mar 30, 2004 | 09:35 AM
MECHAM's Avatar
looks slow
Old Mar 30, 2004 | 09:58 AM
02BlueFirehawk's Avatar
He needs a TH400 I think.
Old Mar 30, 2004 | 10:03 AM
Dave, what do you have to do to get the 800 rw that they dyno'ed for you out west?
Old Mar 30, 2004 | 10:54 AM
take the pump gas out and put 116 in and turn it to 16psi i guess? thats all that is different set up wise.
i imagine if i did do that i would see 750 or something based on the results from switching the rear and to the slicks (and different dyno)
i'm allready writing santa for some new rings and headgaskets for christmas so maybe this fall we can see how far over 800 it goes.. harlan has done something like 860rw (if done on a dynojet estimate) on a stock crank so i dont want to go too far until he goes...even further..
Old Mar 30, 2004 | 11:13 AM
Crunch's Avatar
I second that.
Old Mar 30, 2004 | 11:21 AM
BIGBOS's Avatar
Th400's are good........
Old Mar 30, 2004 | 12:24 PM
nevarr!!
Old Mar 30, 2004 | 12:46 PM
kp's Avatar
kp
Congrats, getting down there..
Sometimes i wish I still had the M6, if its a street car they are a lot more fun - just hard on parts if you drag race a lot.
You would be flying with an auto though
Old Mar 30, 2004 | 01:07 PM
buschman's Avatar
Don't listen to em Dave. "Stick" with the man's transmission and drive your times. If I wanted to ride fast I'd buy a plane ticket
I'm at work so I'll check out your dyno runs when I get back. Congrats anyways. Numbers sound good.
Mike
Old Mar 30, 2004 | 01:15 PM
I'm thinking the stock crank can do it. Come on man, put some Jet fuel in that fugger and turn it up!
Old Mar 30, 2004 | 01:16 PM
Mike
Yeah but wouldn't you rather win races effortlessly? lol.
Old Mar 30, 2004 | 03:52 PM
buschman's Avatar
Nope, anything worth winning, is worth driving for Plus I'll take a car that is more enjoyable 99.99% of the time, versus that 0.01% that I'm in the 60' stretch
Mike
Old Mar 30, 2004 | 04:08 PM
Mike
Well then apparently you've never launched an auto before. It's worth it just to launch like a raped ape.
Old Mar 31, 2004 | 06:55 AM
GTP40's Avatar
Would you care to post any of your datalogging files? It'd be interesting to see how the beast is really behaving.
Old Mar 31, 2004 | 07:44 AM
cablebandit's Avatar
Glad you are having fun with the car. I'm surprised you couldn't get the 60' down some but I guess track prep wasn't that great. You will love launching off the 2-step. It really helps you adapt for track conditions.
Old Mar 31, 2004 | 08:01 AM
hmm ya i can, not sure what format i can switch these accel files to.. anythign in particular i can just tell you?
timing at max boost was 24*, wideband afr was 11.4, no knock set up on the dfi.
Old Mar 31, 2004 | 08:06 AM
i have run the 2 step before, love it.
i can definitely get the 60 down some more, but not in one run.. and i thought that was a pretty good launch for a laggy single turbo off idle
