catch can setup question?
Old Jun 11, 2012 | 09:31 AM
burbalanche's Avatar
Default catch can setup question?
ok im trying to figure out how i can do this on my setup.the port rite behind my tb was broken and blocked.so my ? is would it work to run a line from each valve cover to my vented can and then run a line from my air filter on my turbo to the other port on my can bringing in fresh air?
Old Jun 11, 2012 | 09:47 AM
a4ls2goat's Avatar
The way I have it setup is is just 1 line from each valve cover to a vented catch can.this way you have no chance of getting oil to the motor from the pcv system.
Old Jun 11, 2012 | 10:32 AM
conan's Avatar
If your running a vented catch can you dont want to hook it up to the turbo inlet. It will just suck air from the little air filter on the catch can instead or pulling VAC on the motor. Have a look through this thread...
https://ls1tech.com/forums/forced-in...rs-inside.html
Old Jun 11, 2012 | 10:36 AM
Oh ok thanks for the direction guys
