Head gasket failure - opinion?
And worse again...often the electrode can end up down the side of the piston scraping and causing damage.
it would be very wise to pull the pistons and inspect for damage and ringland damage.
It's pretty common for race cars making 20+lbs of boost to go through gaskets alot. Expecially with stock (thinner deck) heads running just 4 bolts per cylinder.
We have run as high as 40psi on a 10:1 engine on E98 non intercooled. You do need to try and light off as much as you can though. We ran AFRs on the gas scale at 9:1. When we converted to M1 with a alky sensor we seen 3:1 with the eth tuneup just changed for the fuel constant.
*the white speckled stuff on the piston in engine is lithium grease i sprayed on. Not to be confused with severe detonation...lol.
I would definitely remove all pistons for inspection though. Back to my original post, whether it was heard, logged or whatever, I'm back to thinking detonation has been responsible for losing the plug tip and subsequent damage.
Although you can get fancy racing plugs that have a special electrode that is much stronger. It's just a small piece of straight metal welded on at an angle instead of the normal L shaped bent electrode. They are very expensive though, but designed that way to help prevent the tip disappearing.
WCCH LSA heads, 370 iron, ls9 gaskets
was out prepping for track passes and it never moved any water on 16psi and 20*
10:1, e50, with a 5gph nozzle of 50/50
same turbo too
i have a twin turbo cummins and they use a MLS gasket.... and with arp studs after one heatcycle the initial retorque is ridiculous IMO how much more you get out of every nut
it is less and less every retorque until there is no movement, but that initial one moves alot
Broken ARP stud 3 1/2 inches below the deck
After 10 minutes of "%^&*" I thought and thought.... how the hell do you get to that. I have all sorts of extractors... but nothing that long.
Well it turns out the way it broke, the broken stud itself could be used as a key. Ya I held my breath. Sure enough using the stud and pushing it in while turning, it backed right out. Im glad they are only hand tight.
My next question.... I torqued them all down to 90ft-lbs. I know its 10 more than specs... but it went to about 85 and got about 1/8 turn more, still at 85 and snap.
Faulty stud or is reaching for 90 too much to ask??
Potentially could have been bad night....im walking away while im still ahead.......wheew.
Im glad I also have an extra incomplete set of head stud.
I also dont see why people would want to exceed the torque spec by so much ?
Failure is probably just a combination of bad luck with perhaps a little too much torque applied.
