Head gasket failure - opinion?
-stock 317 heads (patriot extreme springs)
-TU1 cam
-9.8:1 compression
-E85
-Timing 14.5 degrees
-A/F 11.4:1
-PT76GTSH Wastegate closed mechanical gauge said 20psi electronic said 21psi
-Standard GM MLS gaskets (<-----Failure I know)
-ARP head studs.
So I got my Eboost2 working and my set on kill stage did just that. Last year I had it set on 18psi and ran what the vid in my sig shows.. Upping the boost just this little seem to make quite a bit of a difference.
Anyone ever re-torque the heads after its ran? I dont know if that would have helped? Seems like a pain in the *** to do..
The heads trashed. Glad it was just a stock one.. I have spares. Everything else looks ok. The LS9 gaskets I think were back ordered or something so thats why i didnt get them then.
Im going to get the LS9 gaskets, put it in the car and run it w/ no manifolds to heat up and then re-torque them before putting it all together.
Sound good?
Kind of hard to see the head, but those grooves cut in are about 1/8" deep.
At least it was fun breaking it...lol.
Now I'm starting to think. When a powerful engine like this does blow a head gasket, is actual alloy damage to head/block just expected ?
I find it hard to believe, but it does seem to happen quite a lot. So is there no such thing as a simple head gasket blow and almost no damage ?
Which studs, how were they torqued, were studs installed loose ?
Ive never had a head gasket failure per-say, but I have had serious damage like the above and believed detonation was the cause. And still do in my case.
I've never re-torqued once installed in the car though. On occasion I have torqued, let sit for a few hours, then undone each nut and re-torqued one at a time.
Cant say if it makes a difference, as sometimes Ive done it, some I havent. Usually torque to around 75-80lbft cold with regular ARP studs and GM gaskets.
Plugs looked ok except for one missing electrode. It might have been done at 18 but made a lot more this way
I probably wont push it that hard again.
Studs installed finger tight, ARP studs torqued to 80. Reason I ask is I have a Eagle Talon i put head studs in, same kind. They are super accesible to after I ran it up to temp a friend told me to check them. Sure enough I got about another 1/4 turn out of the nuts before they were at the proper torque. This was running it up to operating temp and then letting it cool.
I use the ARP "Ultra-Torque" lube (the most consistent lube available) and torque each fastener in steps to its final torque rating. for example - install studs by hand - torque the cylinder head in the proper sequence to 20lbs. then the whole sequence to 50lbs, then 80lbs. then undo all of them. Repeat 5 times. I know this is overkill, but helps to get a more accurate torque reading, and better consistency between each stud. It takes me about an hour to torque down the heads doing it this way, but it helps to stretch the studs, so that they won't stretch during use.
im not saying this is what caused your failure, just advice for when you put it back together
The HP calculators online say 141mph @ 3700lbs = 850hp. ??
Adding the 2-3 lbs of boost and getting the A/F dialed in made a big difference. The car turned into an animal.
Heres the only vids of when it blew. The guy said the supra just dynoed 1033whp before they left, this is about a 60mph roll. First run the car was running hard. Second run it didnt hit as hard when I hit it...we were about dead even and then I just lost all power and created one hell of a white smoke show for my friends following us. Thats about the only thing I got to compare it to.
Vids of the car I found and his ebay ad.
http://item.mobileweb.ebay.com/viewi...917&cmd=VIDESC
I really dont know what its "supposed" to be... All I do is guess and check.
