"limit" of boost on Pump gas
Old Jun 15, 2012 | 06:05 PM
jt76's Avatar
Default "limit" of boost on Pump gas
Right now I'm only running on 8psi with 93 octane, 17* of timing. If i were to turn it up, how high should i go before considering going with a higher octane fuel. We also have 100 at the pump around here, that is an option, otherwise i will have to pony up for a drum of race fuel if i want to go higher octane than 100.
Old Jun 15, 2012 | 06:07 PM
alexcoreas's Avatar
Why not run Meth? I'm limited to 91 in Cali, Meth is my only option so ill be going that route.
Old Jun 15, 2012 | 06:10 PM
jt76's Avatar
Meh.. not really interested in meth injection or E85 at the moment.
Old Jun 15, 2012 | 06:34 PM
pwrtrip75's Avatar
My old 6.0 ran 15psi on 93 octane with 23 degrees of timing. Never had a problem till the thrust bearing went out.
I would throw 15psi at it, drop the timing some, and then slowly add timing logging it and keeping an eye on KR and keep an eye on the AIT's. If all good increase to 18psi and repeat the process.
Old Jun 15, 2012 | 07:31 PM
abbaskhan's Avatar
To many factors like charge temp, dcr, type of FI, etc etc.
Old Jun 15, 2012 | 10:48 PM
ablakez28's Avatar
I was doing 17 PSI on the 418 making 900+ rwhp on pump.
Only ran 14* max on that level to be safe. I was mixing in a few gallons of C12 whenever I would go over that. 18psi 15* was what I made 975rwhp on but the a/f was horrid(10.2/1) on that run and we ended the session when the coolant hose blew up. Wouldn't mind bringing it over 1krwhp on the 93/c12 mix if sobo wants to sometime.
PS - I was buying the C12 at the pump at Pautlers on Broadway.
Old Jun 16, 2012 | 01:21 AM
denmah's Avatar
Moderator
im hitting my junkyard 4.8 with 22lbs, 12deg, and a 125shot on pumpgas +meth
Old Jun 16, 2012 | 01:25 AM
alexcoreas's Avatar
What numbers did you make with the 125?
Old Jun 16, 2012 | 03:00 AM
shawnzy89's Avatar
Convince sobo to make more jams!
Jim, you need more jams too...
Old Jun 16, 2012 | 03:29 AM
denmah's Avatar
Moderator
i havent dyno'd but i trapped 138 on a 1.77 60ft and car is 3100 with me in it
right around 675rwhp est
Old Jun 16, 2012 | 10:02 AM
venom ws7's Avatar
Somewhere between 15-17psi is the max I'd run with little fat A/F to be safe.
Old Jun 16, 2012 | 01:12 PM
stevieturbo's Avatar
You dont state whether intercooling is any good, nor do you state what CR you are using.
So it is impossible to give any answer.
