Lets talk electronic boost controllers!
Old Jun 21, 2012 | 12:29 PM
El_Diablo's Avatar
AMS-1000 You get what you pay for.
Old Jun 21, 2012 | 12:36 PM
RedRocketZ28's Avatar
I was looking at going with the Eboost 2, but got an AEM Truboost for free from a buddy. We will see how it works out.
Old Sep 15, 2012 | 04:21 PM
lsd01's Avatar
Were do i mount sts electronic boost controller on my 2000 Camaro
Old Sep 15, 2012 | 05:59 PM
driven87's Avatar
gonna be trying Boost Leash next year with CO2...got an AMS 500 right now but want a little more options
Old Sep 15, 2012 | 06:57 PM
FasTimeSS's Avatar
Ams1000 close this thread
Old Sep 15, 2012 | 07:34 PM
skinnies's Avatar
I love my hyperkontrol, mph based off front wheel and can set per every ONE mph.
Old Sep 15, 2012 | 07:37 PM
SPRAYED 01's Avatar
Whats the cheapest controller that I can set a low boost on tbrake launch. Then have it ramp up like .5 secs later?
Old Sep 15, 2012 | 09:38 PM
Cam72aro's Avatar
You should, for $1500, lol. I am sure its nice, but c'mon most of us average joes can't spend that much. My gt91 wasnt that much. I will eventually probably buy the ebost 2. Seems like a lot of options for the price.
Old Sep 16, 2012 | 05:00 AM
skinnies's Avatar
It wasn't cheap, but worth every penny. It's also why I can run low 10's on pure street tires and not have to buy drag radials to go racing and have fun. It definitely pays for itself, I would've LOVED to have it on my rx7.
Old Sep 16, 2012 | 05:35 AM
stevieturbo's Avatar
For $1500 you could buy a complete engine ecu that will also offer launch control, boost control etc etc etc
$1500 for a boost controller on it's own is just mental.
Old Sep 16, 2012 | 07:36 AM
skinnies's Avatar
Show me one that will work off front wheel speed per mph built into a stock ecu setup with everything for an ls1 for 1500.
Old Sep 16, 2012 | 07:56 AM
  #32
Silver T's Avatar
On my v6, I used the old school innovative controller with co2. It has 5-6 stages and ramps in-between all of them. Can be triggered between each stage or can be set on a timer. Always was a solid piece.
I've tuned and installed the ams500. It is a 2 stage controller with a ramp setting in-between the 2 stages. You can find used 500's for right around $300. The 500 is great for your normal street car. It actually works pretty good off of manifold pressure too. The 1000 is great for a mainly track car. Definitely has a learning curve to it. Never seen anyone use the 1000 off of manifold pressure though, not sure how it works if you don't have co2.
My 5.3 project is getting close to being done. I got the Holley efi system for it. Hope to use the ecu's controller when they release it. A guy locally is using the beta version and it works well from what I'm told.
Old Sep 16, 2012 | 09:01 AM
  #33
The DTA S80Pro Ive been using for 5 years.
it can do boost by gear, boost my mph or simply boost by rpm.
It also has launch control and traction control built in, and anti-lag if you wanted it.
Old Sep 17, 2012 | 09:04 AM
  #34
RacerXLs1's Avatar
Hows the msd boost contoller, i heard good things about them?
Old Sep 17, 2012 | 11:23 AM
  #35
rotary1307cc's Avatar
Ams 1000. Should have got one long ago
I run compressed air instead of co2 aswell, so no filling co2
Old Sep 17, 2012 | 11:44 AM
  #36
MIGHTYMOUSE's Avatar
IF i was to build a new true street car it would take A LOT of convincing to get me to even try anything other than an e-boost. I barely scratched the surface of its capability.
Old Sep 17, 2012 | 01:28 PM
  #37
Ferocity02's Avatar
e-boost street here. Haven't actually gotten to use it yet, but it looks and feels nice. Good features for a street only car. Good reviews on here as well. Got it on eBay for under $300.
Old Sep 17, 2012 | 01:30 PM
  #38
dville_gt's Avatar
Originally Posted by Fbodyjunkie06
I have never played with an E-boost but it sounds like it has a lot of the features some of the higher end more $$$ controllers have.
I like the Boost Leash boost controller by Leash Electronics. Randy makes some AWESOME products and the boost leash allows 5 timed boost stages and a launch boost stage. You tell it how long you want it to hold that amount of boost for and how fast it ramps to that boost number and that's it.
You can have one big long slow ramp stage with your target boost at the end, or split them up into 2, 3, 4, 5 stages.
You can also set-up the last stage as your "spool-up" on the footbrake boost setting.
What this does is when you turn the controller on it runs through it's stages and stays at the last setting until the transbrake button is pressed and released and then it cycles through it stages again.
So set the last stage up at the boost you want to target on spool-up on the footbrake to get the turbo going, bump into the lights and when you grab your transbrake it inputs to the controller that it's time to go back to the launch stage boost setting and when the transbrake input is released it starts back at stage 1-5 or how ever many you are using.
So you set your last stage at say 5psi and have it ramp in really quick and since it is the last stage it will stay on that setting for as long as it needs to until you grab the transbrake which starts it over again at launch psi.
another vote for the boost leash..
ams1000 functionality at about 1/2 the cost. lots of VERY fast cars using this setup.
Old Sep 17, 2012 | 02:41 PM
  #39
The thing about most aftermarket EBC's though, all they are trying to do is match what a decent engine ecu can do already. Except it requires more installation work.
I do like EBC's they are usually simple and do a very good job. But there comes a point when a proper engine ecu is a better option, and hearing some prices quoted for EBC's, cheaper too !
Old Sep 17, 2012 | 04:08 PM
  #40
98Z28CobraKiller's Avatar
Restricted User
The AMS1000 is the standard. No question about it but it does have it's drawbacks. The way that they do their ramp rates is very confusing and can sometimes require a little pen and paper to figure out.
The AMS2000 is much better (and even more expensive) as it uses a PC interface and allows for more plotting/stages.
I personally ran teh AMS500 for a little over a year and it worked very well. Specially with CO2. I will never ever bother messing with boost control without CO2.
So the only reason that I sold my AMS500 is because I am now using the Holley ECU and am beta testing the boost control. This new boost control has as many or more features than the AMS 2000. The one thing that the AMS does do better is that they've managed to come up with some sort of universal algorithm that just works without giving the controller any control guidelines (P.I.D. Control). With the Holley, you have to go thru a setup process to see how your particular regulated source pressure, solenoids and MAP work together.
