What crankshaft...22psi....single 94mm....iron 408ci...????
#61
#62
yea and a f1r is rated to 1300 but has cars going 4.78 at 145+ in a 3300 lbs car(comes out to like 1300+whp threw an auto). but then how is say a large frame or even a mid frame 88 rated for around 1500fwhp. but still your recommending a 94mm turbo(1600 crank) for a car shooting for 1k wheel.
#63
While that may be true those cars are meant for that and every part of their equation is perfectly adopted for that blower or turbo. While in this case, its a street car. Plus the guy is on somewhat of a budget. A PT94 is $2600, where an X275 88mm is $3700..
#66
Yes. If you're happy with it then go with it. It seems like a full proof plan. Make sure he pins the main caps. Thick Deck Head and LS9 Headgaskets with Properly Torque ARPs and you're set.
#67
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#68
if he's on a budget, why not a 47-88? you can find em all the time in good shape used for $12-1400. i got mine with a handful of 1/8 mile passes, looks like new, and hot coated for $1300 and is good to either 1450 or 1500 hp depending on the website you're viewing. that's a pretty decent bang for the buck imo and isn't as heavy as say an 88mm bw turbo. just a thought. but i AM a newb actually hahaha
#69
#73
The GT4788 would be nice. I would use Garrett over Precision right now. Seems to be some problems with them. See if you can get a T6 verision if not a big A/R T4. The 4788 Turbine is somewhat "small".
#74
yea if your shooting for 1000. just go with a t6. dont try and make a t4 work cause its just a waist of time if you run into back pressure issues on the t4. then you would need a new merge to t6 and a new turbo in t6
#75
For a budget build you cannot beat the BW S480 96mm turbine 1.32 a/r. Will make 800 + rwhp all day long for around $800-900 brand new. They are a great unit that can easily be rebuilt into other sizes when you max it out (billet 83, 88mm). Very reliable units that you never hear about failing.
#76
#79
I've owned a 80/83, 80/87 and presently have a 83mm billet/ 92 turbine.
presently at 706/649 hp/tq on a Mustang dyno, converter unlocked and 14% slippage of the torque converter
390, etp heads.
