LS1 or LQ4 accessories
I'm starting to get together all the parts for my TT build. I bought a 06 LQ4 engine for my base. I have a 99 LS1 in the car now. I'm torn between using the truck accessories intake and tb or swapping in the LS1 parts. What do you think.
If your doing it in a fbody id swap it over,its all easy to swap. Only thing is you have to drill and tap a hole for the alt bracket. Otherwise youll only have the lower bolt and the rear stabilizing bracket off the alternator.
