will i meet my goal
Old Jun 26, 2012 | 01:04 AM
stangtrader's Avatar
Default will i meet my goal
alright guys,im in the process of a new build and am trying to figure out the motor side of things.my goal is 700rwhp out of a 5.3 backed by a rmvb th400
with a 3700rpm stall thru a 8.8 in a mustang. i am planning on running a stock 5.3 with head studs ls9 gaskets,228/232 115lsa cam and a borg warner s475 or s480.it this doable? if so am i better off going t4 or t6?im currently leaning twoards the s475 t4 turbo,but if the t6 version should spool fine im good with that.car is being built as a low buck drag car that will also see street duty. your guys input would be highly appriciated
Old Jun 26, 2012 | 06:39 AM
JAX04's Avatar
I have not done any tinkering with anything yet, infact i just asked for advice last week and havent touched anything with it yet, tune wise.
2004 5.3
223/230 114 cam
LOW RPM stall, somewhere around 3000k
borg s475 turbo using the twin scroll
no two step
E85
NO innercooler either
i cannot build any boost on the brakes, however, i have not changed my brake pedal for more leverage yet after the manual swap, i have stock calipers out back, etc.
So, trying to build boost on the brakes at the moment, does not work... lol just pushes through, this is probably due to a lot of things, listed above.
Anywho, without a two step and without fudging with the tune, probably around 25* of timing on the brake, and 12.0 afr and it blew open the wastegates in about 4 seconds on the transbrake, 9psi springs, dual 46mm precision gates.
I have not raced it, i have not done anything more then mess with the tune in the driveway and light cruise around the street, i put a hole in my radiator on friday or i wouldve been out boosting the **** out it. Ill report back once i get rolling more.
Old Jun 26, 2012 | 03:36 PM
Good to know,yeah shoot me your results when you find out
Old Jun 26, 2012 | 04:27 PM
alexcoreas's Avatar
Stangtrader are you going to go.FMIC? OR JUST STRAIGHT E85?
Old Jun 27, 2012 | 12:38 AM
I plan on both but worst case ill be on 92 octane and meth
Old Jun 27, 2012 | 09:33 PM
chevellepowered's Avatar
im running ly5,, stock 08' 5.3 243 heads. .. same exact cam.. on a magnum 76mm..same as mpt76 ,, 14lbs made 550rwhp thru a 4l80e locked converter. 2nd gear pull... 12bolt chevelle ..running 19lbs now...... 700rwhp is big numbers.. its possible..
Old Jun 28, 2012 | 07:27 PM
Awesome, you possibly have any idle clips? Im real interested in how that cam sounds, im wanting some chop at idle
Old Jun 28, 2012 | 10:52 PM
first video this is on 10lbs
Old Jun 29, 2012 | 12:03 AM
ha ha thanks man,that second vid with the higher speed rolling burnout looked like ya might have pooed your self.car looks like it moves out pretty good.thanks again for the clips
