PT 91.5 370LSX F Body
Just figured I would share some progress pics on my car. Big thanks to Nolan (BMXARMY) For the awesome fab work, pretty excited with how its turning out!
As far as goals id be happy with anything in the 9.XX range, eventually id like to try for an 8. Specs are FPS built 370 Stock crank, Howards billet rods, diamond pistons, stock 6.0 block ported 241 heads, Vic jr intake, Extreme automatics spragless 400, PTC converter, midwest chassis fab 9 with moser aluminum center, afco double adjustable coilovers.
Do you mean 317 heads? Those are what come on the 6l's. Only reason I ask is because the 241s would def be a weak link in the combo if that is what you have, the 317's would be much better suited running that much powa. good luck with the build, I like the cross over.
