how much boost with no tune ?
Old Jul 26, 2012 | 08:11 PM
  #41
Camaro9969's Avatar
No matter what anyone says to do a Turbo build plan on spending 6k+ easy.....no such thing as a budget Turbo build
Old Jul 26, 2012 | 08:31 PM
  #42
I8UR4RD's Avatar
^ now I am just waiting for "that guy" to come in that built his for 2800 out of soldered campbells soup cans, and a hamster wheel. 12 lbs of hamster will get that sum bitch a movin!
Old Jul 26, 2012 | 08:33 PM
  #43
Fbodyjunkie06's Avatar
None.
Old Jul 26, 2012 | 09:08 PM
  #44
Ryans99ls1's Avatar
i think we're being trolled. if not, follow skinnies advice
Old Jul 26, 2012 | 11:44 PM
  #45
BottleFedZ346's Avatar
I recall denmahs car being put together for less then 4k and going bottom 10s @ 136mph....
Just saying lol...
Old Jul 27, 2012 | 10:03 AM
  #46
93M6Formula's Avatar
Just saying lol...
Don't encourage the guy.......
Old Jul 27, 2012 | 10:54 AM
  #47
SPRAYED 01's Avatar
I want to see the build thread
Old Jul 27, 2012 | 04:12 PM
  #48
Camaro9969's Avatar
4 grand didn't include the trans and rear did it???
Old Jul 27, 2012 | 04:37 PM
  #49
M1tch's Avatar
Read a book..
Old Jul 27, 2012 | 07:41 PM
  #50
Adam123's Avatar
Ummm... Why try to run without boost while having a turbo? If you don't want boost; keep your rpms low, below 2500 depending on turbo size and spec's. I don't understand why someone would want to run without boost having a turbo. If done properly a turbo can make your engine more efficient thus give you better mpg.
This is why major car manufacturers are going to small cubed turbo'd engines. Makes the same or more hp as the bigger motors and will get better mpg.
I just can't stand the dumbass liberal names they give these engines ; ecoboost, eco...uuuuhhh. I h8 this green **** shoved down my throat! It's a government made bubble and it will burst! But that's another story!!!
Old Jul 27, 2012 | 08:44 PM
  #51
Yessir!
EVERYTHING in the setup/car was just under 4k, could everybody do it?
Probably not, but it has been done before....
Old Jul 27, 2012 | 08:55 PM
  #52
needaz28's Avatar
if you cant afford a tune you cant afford a turbo setup. Period!! get a cam, some spray,rear end and start reading..
Old Jul 29, 2012 | 08:03 PM
  #53
Ironmancan's Avatar
Originally Posted by blacktransam
Soooo, you want your turbo, on like, a switch?
Originally Posted by devic
yes pretty much
MADMAX did it with a positive displacement blower, turbo would be much easier.
carnage pics that is
Old Jul 31, 2012 | 08:23 PM
  #54
johnny walker's Avatar
Default boost
running 6lbs on mine w/ tune. 448 rwhp. awesome. no problems, then again i don't drag race it.
Old Aug 1, 2012 | 06:47 AM
  #55
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
4" In-Line Boat Bilge Blower-12v Electric Turbo Blower
Power Source 12V - High Impact ABS Housing
Includes Barbs On The Hose Flange Which Eliminates The Need For Hose Clamps
Provides 122cu.ft. Per Minute Air Flow - Draws Only 2.7 Amps For Longer Blower and Battery Life
Compact Inline Design For Easy Installation Meets ABYC - USCG & ISO STANDARDS
Quiet Working - Water Resistant - Length 128mm, Width 135mm, Depth 95mm
It sound like this electric turbo blower would be perfect for your application, as you can turn it on and off. What I find impressive is that it includes barbs on the hose flange so hose clamps aren't needed. I can't believe I never thought of this before! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 7, 2012 | 09:19 AM
  #56
Camaro9969's Avatar
Hahahahahahaha
Old Aug 7, 2012 | 09:30 AM
  #57
redtan's Avatar
Stock tune = 12.0 AFR and some 20* timing
8psi of boost on that AFR/timing = boom
In for results
Old Aug 8, 2012 | 08:47 PM
  #58
Cronic_Moronic's Avatar
It did. Fuel system, engine, computer, converter, the car everything.
And it actually didn't die till the oil pump o ring went out.
The fact is later model lsx engines are stout enough to hold quite a bit of boost and the Chinese can manufacture parts that work.
Old Aug 9, 2012 | 01:51 PM
  #59
98blackbirdta's Avatar
I think youll be fine as long as you stay under 20lb of boost. just hook the turbo up to a cut out no need for a WG or BOV
Old Aug 9, 2012 | 04:20 PM
  #60
whiteboycntdnce's Avatar
im just asking to kinda find out where i want to go with my car, i plan on getting a cam, and i can fab up my own system just not sure as far as the tuning aspect of it goes
and im kinda wanting the turbo to just be on demand kinda not in use all the time
