how much boost with no tune ?
im not sure if you have already set you car up, but either go fully turbo, or just get a heads and cam and call it a day. Unless you want a super expensive variable nosal or variable AR housing turbos, your not gonna get the desired effect that you might be looking for.
as for tuning, one of them said it right, you "can" get away without tuning on super low boost like 4psi and under with fuel upgrades like bigger injectors and a fuel pump and a return FPR with boost referencing (which you need anyway), but your just wasting fuel and handicapping your build with the possiblility of detonation if a fuel pressure drop or a really hot day came about. Get a mail in tune to at least get your timing and fuel near boost needs so you can at least putt it around town without blowing the motor on stock timing.
