E85 guys come in...
Old Jul 6, 2012 | 03:24 PM
1BADAZZSS's Avatar
Read my other post
Old Jul 6, 2012 | 03:36 PM
LS1FREEK's Avatar
13 Second Truck Club
Originally Posted by 1BADAZZSS
Friend is running 30* on 20# on a stock long block 5.3 with twins. Wont grenade, he's tried lol
Holy crap.... That's insane, and I love it! E85 must be really hard to pre-detonate on. It does seem as though if you run low timing (10ish) on lower boost (10-12) E85 makes less power than 91oct does... well I'm gonna try 18* on 16#s and be a little more aggressive on the IAT table.
Old Jul 6, 2012 | 04:34 PM
98Z28CobraKiller's Avatar
Restricted User
Alot of factors come into play. Static Comp, Dynamic Comp, plugs, back pressure, and race weight are just a few of the major ones. Best thing to do is get on a dyno, start off safe and turn it up until it doesn't make anymore power. 99% of the time, e85 will stop making power before it gets into detonation. Specially on a dynojet (no real world load).
Old Jul 6, 2012 | 07:13 PM
LS1FREEK's Avatar
Yeah, we just dont have a dyno near by... Now I might be getting the static/dynamic CR's mixed up but correct me if im wrong. Im not sure where a good dynamic CR calculator is so I'm not sure what it is but the engine has LS1 MLS gaskets (slightly bigger bore) and is otherwise stock, that should mean the static compression is around 9.3-9.4, and the exact cam specs are 212/212 .561/.561 112 +4, and the spark plugs are NGK BR7EF.
The hot side of his home grown turbo kit has stock truck manifolds, dual 2.5" from there into a single 3" and into the turbo (Magnum BB 76mm with the 64x74mm exhaust housing) and then a 3.5" DP with a cutout.
Hope this helps to get some intput on how much timing you guys could recommend.
Old Jul 10, 2012 | 10:58 PM
LS1FREEK's Avatar
Well he ended up running pretty good on about 15.5 psi and 18* timing!
http://www.youtube.com/watch?nomobile=1&v=2cxaNrKW-HA
Old Jul 11, 2012 | 12:29 AM
Most Hated's Avatar
nice looks like it takes off harder than mine lol
Old Jul 11, 2012 | 06:03 AM
LS1FREEK's Avatar
Close but not! He had a 1.75 on that pass, his best was 1.73 for the night. He has a two-step, but is leaving off the foot brake with a 3200 stall.
Old Jul 11, 2012 | 08:26 AM
spinya's Avatar
Originally Posted by boss79z
Just got mine tuned, and not quite done.
Stock bottom end ls1, 47xxx, ls6 cam, Kytp kit with a pt 7675, e85
We are having boost creep problems with the pw46 wastegate, so haven't pulled it to high yet. I live in San Antonio, so with the heat it made 602 rwhp, 570 tq with 12* timing, 12.5 lbs, pulled to 5800.
In a month or so, we will be adding a 50mm wastegate from josh at kytp, and extending the exhaust out the back. The plan is to bring it down to 10lbs, run 14-16*, and pull it to 6200. We think it wil be close to 650 rwhp.
Who is doing your tuning? I am in austin and have a few options but would like to hear from someone happy with a e85 tuner
Old Jul 11, 2012 | 08:53 AM
oange ss's Avatar
What's everyone doing with their IAT tables ? I zeroed out the cells up to 140* then start pulling 2* and slowly ramps up from there.
Old Jul 11, 2012 | 02:36 PM
TransAmatt99's Avatar
E85 is great stuff my tuner in columbus says that you can pretty much run no intercooler at your regular n/a timing. I just wish I could get it around where I live so I dont have to run avgas.
Old Jul 11, 2012 | 08:36 PM
MJD's Avatar
MJD
No intercooler here and no problems. Numbers in my sig were put up with IAT in the 150's.
Old Jul 11, 2012 | 08:56 PM
  #32
Ryans99ls1's Avatar
Same here
Old Jul 11, 2012 | 09:02 PM
  #33
adrenalineaddiction's Avatar
Nail on the head, mine started losing power above 19* without Knock. No reason to keep throwing timing at it if it doesnt produce power. But mines a completly differant beast, 408 at 18 lbs boost. Best way without the dyno is to watch your mph at the track, if u add timing and mph falls your losing hp. Good luck
Old Jul 12, 2012 | 07:45 AM
  #34
rotary1307cc's Avatar
10-16psi, and my timing is always around 19-20* on top, a couple lower at peak tq
e50 and a little bit of water/meth
Old Jul 12, 2012 | 07:51 AM
  #35
Fbodyjunkie06's Avatar
Originally Posted by Old Geezer
What are the plugs telling you??
No one on this part of the forum believes in reading plugs, blind faith if you ask me.
Old Jul 12, 2012 | 09:32 PM
  #36
Bingo! If you can make more with more timing do it, if not then theres no reason to add it and you have an even larger safety window. Downside is not all these cars are track legal, mine for example isnt because I dont have a cage, etc.
