LQ9 whipple build
lq9 block
317 heads home ported
harland sharp 1.7 rockers
comp beehive springs and chromoly pushrods
cheater v.3 blower cam
whipple twin screw blower
summit 85mm TB home port
ls2 timing chain
stock ls1 crankshaft
melling oil pump for ls1
mezerie electric water pump
volant CAI
the rest im not sure on, i dont even know what pistons of comp ratio i should be aiming for, even what boost id like to run. these kind of things i have no idea on. thanks for any input/advice.
I have read several builds on here where they have pushed 15-18# but they done usually last too long unless the tune is spot on. If you want to put up big numbers build your shortblock so it can handle some abuse.
