***3/11/13 UPDATE*** Project Xtreme Boost! '02 Xtreme Blazer, Single Turbo 5.3
#44
Another very productive weekend! I changed up a few things again, but nothing crazy..
Changed up my downpipe to run between frame and transmission. Got it to clear great as I plan on running some new style Z06 wheels up front.
Anyways, got fuel system done, driveshaft in, turbo feed/drain done, water pump heater core outlets done, everything painted nice, core support back in and finished some small odds and ends on harness.
It's finally started looking like a complete vehicle again. Should have it to where I can tune it this week sometime.
Here's some more pics!
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6314.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6315.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6316.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6319.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6320.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6322.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6329.jpg)
I can see you!
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6337.jpg)
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6340.jpg)
I can see you!
![](http://img.photobucket.com/albums/v325/kandykane12381/Xtreme%20Boost/IMG_6350.jpg)
#52
Yup I know what your talking about. The other s10 I built, the guy ordered a twin setup with shroud, super low profile like 2". Runs like a champ. I'm cheap as ****, so I'm gonna hit up the local salvage yard Tuesday and try to find a twin setup from a Concorde or northstar setup. Hell worse case ill run both push and puller and have PCM turn the both on. I'll keep you posted.
#54
http://www.ebay.com/itm/CHEVY-S10-S1...item2574d0ea9e
Pic below of the S10 I built several months back, truck accessories with this fan setup above. BUT he did not have as much clearence as I have for some reason.
#55
i really like them fans they look like they leave alot of room for clearance. it looks like they just made a sheet metal shroud and mounted a couple fans on them. im thinkin about just getting two low pro fans from jegs and making my own shroud. that way i could put my intercooler up front again. and it wouldnt cost so damn much. $250 is pricey
#56
