Back to Mexico-5.3/PT88 Z28 vs 3.4 whipple/nitrous Cobra
#41
i was told about 80k miles on the engine when purchased, and yes its a home made setup with truck manis, i will tell you though even though the engine itself is budget, i have a good amount of money into the rest of my drivetrain and suspension
im doing a couple other 5.3 builds using l33 HO's for some guys around here so i cant wait to see what those things can handle
#46
Honest after these vids thats my fav camaro on tech, a few reasons why, 1. Its not an over the top setup that cost a crap ton of money to build,5.3s are cheap,no fi setup is cheap but its within reason, and anyone can do weight reduction, major props on the camaro, i hope my build turns out half as good,the owner should really be proud, i wish the owner could maybe put together a build thread/more info about the car,again thats great work
#47
Thanks and like i said ive never been happier with the car, i actually just purchased strange double adjustables all around to replace my konis, so i should loose a little more weight and get some better traction
i have a build thread ill link it to here
#48
https://ls1tech.com/forums/forced-in...t88-build.html
ive since cut out the whole upper rad support and deleted the hood latch ***. and installed aerocatch latches, and remuade the cold side
#50
