Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
#224
Carl is going to help out get the Holley set up and running, it's pretty user friendly though so I'll be tweaking things along the way. Cylinder pressure is cylinder pressure, the compression just gives me a head start in making HP. It will be much more enjoyable out of boost now, this will be the best driving combo I've had since it was stock! I still have no worries taking it up to 1500 flywheel on E85.
New turbos are Turbonetics billet 6468 .81 A/R T4's.
Morel 5274 lifters.
Morel 5274 lifters.
#236
So how has transmission life been? Would think its a lot better than a 3.622 or 4" motor.
Your car looks awesome btw, can't wait to see the new numbers from your twin set up/ new motor.
#237
I still haven't gotten the new setup running, but it's finally getting closer thanks to Nate! Fall-Winter is the busiest time of year for me work wise, and especially this year getting engaged and buying a house, so progress has been non-existent lately. Nate got the MWC 10 point welded in and painted, and helped get it together. Next up is some catch can fabbing, radiator plumbing, and exhaust work. Finally its off to another shop to get everything wired up! It will be running by the time spring rolls around. Almost everything is bolted on and ready to go. I will get some more pics as it comes together!
