procharged ls1 running slow
Old Jul 23, 2012 | 10:16 AM
tranb000's Avatar
Default procharged ls1 running slow
Just took my car to the track was disappointed in my 12.8 run.the motor is a stock bottom end with ls6 intake 1.8 roller rockers patriot gold valve springs running 9 lbs of boost. At wot my wideband read 10.2. I have a p0300 code thrown. I'm wondering if the problem is in the tune. Thinking I might get a cam and y pipe and get a speed density tune but I would think my car would be running a high 11 sec quarter mile the way it is now. Any info would be a great help.
Old Jul 23, 2012 | 10:33 AM
a4ls2goat's Avatar
Post up a time slip.
Old Jul 23, 2012 | 10:36 AM
9sectruck's Avatar
more then likely the tune. if its going 10.2 thats really rich
is it a auto? stall?
Old Jul 23, 2012 | 10:39 AM
black06g85's Avatar
yeah that's too rich and showing missfires...... not usually a good combo.
Old Jul 23, 2012 | 10:44 AM
conan's Avatar
What they said ^^^ and what cam are you running with the 1.8 rockers. Might be pushing some boost down the exhaust as well.
Old Jul 23, 2012 | 10:58 AM
tranb000's Avatar
1.85 60 from 12.85 quarter at 107.74 mph the Cam is stock its a 6 speed
Old Jul 23, 2012 | 11:03 AM
black06g85's Avatar
yeah mph is definitely not there, even if ya had a 2 sec 60' it should still be trapping quite a bit higher
Old Jul 23, 2012 | 11:04 AM
dtsti's Avatar
What kind of procharger?
Old Jul 23, 2012 | 11:10 AM
tranb000's Avatar
D1 procharger
Old Jul 23, 2012 | 11:12 AM
tranb000's Avatar
I'm wondering if it falling on its face at wot
Old Jul 23, 2012 | 11:58 AM
tranb000's Avatar
What would you do if this was your car
Old Jul 23, 2012 | 12:14 PM
35thsscamaro02's Avatar
Retune it! I ran 12.7 @110 when I was just full exhaust
Old Jul 23, 2012 | 12:27 PM
tranb000's Avatar
Could the rich tune be causing the missfire you think
Old Jul 23, 2012 | 12:31 PM
I8UR4RD's Avatar
would love to go over that tune and see whats up. how is your fueling on the car? injectors/pump etc....I never saw if you mentioned what cam you were running. you could also be having belt problems. there is a group purchase on the aster bracket which will solve that going on now. its def worth having if you plan on making any serious power.
Maybe you foul out a o2 sensor dunno what spark plugs are you using
Old Jul 23, 2012 | 12:37 PM
ramairetransam's Avatar
belt slip and tune , are you using a 8 rib setup
Old Jul 23, 2012 | 12:50 PM
4kiro's Avatar
Welcome to the club. I am on my phone so you won't see my sig. I have a 00 SS with full boltons, running a F1A with about 7 psi. I ran a 12.70 at 110 and a second 12.70 at 116. I was having overheating issues. I noticed my fan was not plugged in so car computer was pulling timing. I have a 6speed with a best 60 of 2.25. Haven't returned to the track.
Old Jul 23, 2012 | 12:58 PM
9sectruck's Avatar
^^^^^ you have the black camaro thats in spring field?
raced a red lighting?
OP you need a new tune belt slip or not 9psi of boost will net better then any 12.7
Old Jul 23, 2012 | 01:03 PM
tranb000's Avatar
I'm running 42lb injectors with a racetronix fuel pump with hotwire kit I'm running 8 rib setup with stock Cam spark plugs are the ngk tr6s I think the ones for turbo or blower.
Old Jul 23, 2012 | 01:25 PM
intenseblue's Avatar
Has it ran faster than that and what did it do before the blower?
