Toyota Truck, different LS1 turbo conversion
#81
Engine size and turbo, Thats the least of my worries!! coil-overs, hand made suspension, diff swap, full internal roll cage, 37" tyres, shortened chassis, extended wheel base and track, lexan rear windows, turbo hanging out the bonnet, brake upgrade, beadlocks!! i got NO hope
#82
so im about to put the enigne back together for the last time, just got some ceramic coating to do, I've linished the flanges so there flat as possible there was a couple of lows and highs from the welding, as seen in pic!! What gaskets are most the turbo blokes running?, are the some that are better than others?
#85
Cage finished, QLD Transport approved and all
Front bar started. going to be similar to the last one but a lot higher in the centre.
Passenger View from the Seat! i need to figure out a way to cover it.
#89
Grace period for rule change ends end of next month. They have now adopted National standard (No cage work forward of the B Pillar), about 5ish months ago, with a 6 month transition period. so if you have 6 point ya better be quick getting it approved, NOW or Never!!
#90
Couple of new add on's, Made a big mistake with the beer holder , i did not allow for a stubie cooler, will have to re do that!!
Air ducting to rear air box
Recovered the dash in black vinyl had to cut out the dash for the cage.
Compressor and start of the air box
Air box lid
Battery Mounted
Found an easy way to Notch large pipes just clamped them the lathe EASY!!
Air box lid
Battery Mounted
#96
Yeah that tropical NOrth QLD for ya to hot otherwise, i have built this whole truck in flip flops!!
Home made bud trailing arm Bush's, work real well and are practically fail safe
Thanks mate
Thanks mate
#99
#100
Amazing build mate!! Especially the stubby holder haha. Are you stil selling the engine mounts for ls1 to hilux and I also read in one of you posts you can sell abit of a kit or something ? Cheers Elliot Millen
