Huron Speed TC78 Trans Am Build
#121
Been a while since I posted but have some updates. Getting the engine back from the machine shop today and starting the assembly process. Here is the new setup.
347 LS1
Diamond pistons
Total Seal rings
Compstar rods
ARP main studs
ARP head studs
LS9 head gaskets
Pinned main caps
Ls6 oil pump
C5R timing chain
317 heads
Chromoly pushrods
BTR springs
Tick Performance stage 1 cam
Comp Cams trunion upgrade
Same Turbonetics TC-78
BMR k-member
Hope to have it running this weekend!
347 LS1
Diamond pistons
Total Seal rings
Compstar rods
ARP main studs
ARP head studs
LS9 head gaskets
Pinned main caps
Ls6 oil pump
C5R timing chain
317 heads
Chromoly pushrods
BTR springs
BMR k-member
#123
#124
Everything is done and back together. Fuel system is not enough and had to upgrade the wastegate to a bigger size but the car runs and drives great! I am currently running almost 10lbs. Numbers to come soon
#130
LS1Tech Sponsor
Shoot me a PM and I will get you set up! We have a few V1 kits left at amazing pricing!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#131
How's the build bud? I'll install everything this weekend hopefully on mine. I was missing some bolts for the intercooler to hook up to the brackets. But I grabbed some and hopefully I won't have any other missing bolts.
