Turbo LM7 advice
Old 08-02-2012, 12:59 AM
Karlen's Avatar
Default Turbo LM7 advice
I dropped a junkyard LM7 and a TDP stage 2 t56 in my Colorado last fall, and now I'm looking into a turbo for it.
My buddy has a Turbonetics Tc78 that I'd like to pick up, so I started digging around, reading build threads and so on.
So, here's what I was thinking, and where I'd like advice.
LS6 springs/cam
LS9 headgaskets
truck manifolds
pushrods
ARP head studs
Fuel is also where I'm not sure. I was thinking 42lb injectors and swapping out my stuck Colorado fuel pump for a walbro 255.
Find an ls6 intake or keep stock truck intake?
Right now I'm on a speed density tune, no maf. Should I go maf?
Looking to push 10psi or so, nothing too crazy, at least to start off with.
Thanks
PS
Here's turd truck in all it's glory. I rescued it after 8 years as a work truck.
Here's what I have to play with. It's dirty, I haven't washed it and didn't wash it before the motor went in but that's what the plan is for this winter.
Old 08-02-2012, 01:06 AM
a4ls2goat's Avatar
i would skip the head gaskets and head studs unless you plan on going high boost 18+psi.
also, skip the ls6 springs and throw some better springs.
Old 08-02-2012, 04:56 AM
BottleFedZ346's Avatar
^^^^ what he said!
Also, I would recommend ATLEAST 60lb injectors and maybe a Aeromotive 340 pump for room to grow later!
Either intake manifold will work fine for your goals!
Old 08-02-2012, 06:09 AM
Moter's Avatar
60 lb injectors
Old 08-02-2012, 08:37 AM
trav-tech's Avatar
The stock rods will bend long before the factory head bolts stretch to the point of lifting the heads so I would think you would be better off spending that $ towards a better set of valve springs and larger fuel system. I would stay on the speed density tune.
Old 08-02-2012, 09:32 PM
boosted2.0's Avatar
Default ooo
Talk about a sleeper!!!Cool setup!!Good luck
Quick Reply: Turbo LM7 advice
