Im running out of room...
Old Aug 20, 2012 | 09:00 PM
73AMC's Avatar
Default Im running out of room...
Im running out of room in the AMC to mount the wastegate where it should be, what is preventing me from running it like this guy?
http://image.carcraft.com/f/techarti...ine_guide+.jpg
If he can, why cant I? Like I said, I know where it should be, but space is at a premium. What is the drawback to this? Anyone mount theirs like this? How was the experience?
Old Aug 20, 2012 | 09:18 PM
a4ls2goat's Avatar
that wastegate looks backwards
Old Aug 20, 2012 | 09:39 PM
Tiago's Avatar
deffinately backwards in the pic.
Old Aug 20, 2012 | 10:31 PM
1fastkingcab's Avatar
do you mean mount the waste gate backwards (bad idea) or basically mount the WG in a way that it only really dumps exhaust off one bank of the engine? (good idea as long as your WG is large enough to control the boost)
I basically did the same thing on a single turbo V6 project, I modified a stock manifold to be my turbo manifold and used a completely stock manifold on the opposite side and a very simple crossover (wish i had a pic) very similar to a 98-02 F-body Y pipe but a "U" pipe from one manifold to the other (stock locations) I mounted my Waste gate on the "U" Pipe.
You waste gate just has to be big enough to dump enough exhaust to control boost. If your gate is OPEN and the other 1/2 of your engine still has enough exhaust gas pressure to spool the turbo or even just keep the turbo spooled, then your gonna have boost control issues.
Old Aug 21, 2012 | 05:16 AM
73AMC's Avatar
Basically I want to run it off the passenger side bank. before it merges with the drivers side. More or less on this pipe...
Old Aug 21, 2012 | 05:31 AM
Outlaw666's Avatar
It should be placed where it's getting access to both sides, so at or after the merge.
Old Aug 21, 2012 | 05:52 AM
JAX04's Avatar
That wont work, you'll have boost creep like no tomorrow, im not sure even if you had good placement on that one side if it would work, id still think that since the other primary has priority, it'll still run that turbo...
The wastegate needs to be on the outside of a bend ideally, in this pic, you could almost make a small "Y" between the two primaries for the wastegate.
Old Aug 21, 2012 | 07:00 AM
The Beast's Avatar
Why not put it on the turbine housing?
Old Aug 21, 2012 | 09:59 AM
slow67's Avatar
Gingervitis Addict
They do it all the time over on PT.net, but seem to have a creep problem with bigger turbines (for obvious reasons).
Old Aug 21, 2012 | 04:31 PM
Yea your talking about EXACTLY what I did. But to keep it is perspective I was using a mid sized turbo making 400WHP on a 3.0L V6 and using a single TiAL 44mm wastegate. and like the others have said boost creep can become an issue if your wastegate cant dump enough exhaust gas.
Depending on engine displacement, turbo size and desired boost levels.... Bla Bla Bla you see what im getting at. if you do your math right and you run a wastegate that can flow enough or dual WG's on the same pipe (don't laugh is works on RX7's & S2000's :p )
But ideally very similar to what "TheBeast" said. is there any way to get perhaps a short 2" "J" pipe welded in to the merge collector area just before the turbo flange with a waste gate flange on the end of it.
Here is a Pic to give you an idea.
#1 no not my build and #2 I don't know why they added that 2nd 90deg bend to the waste gate tube. I woulda left it with the wastgate outlet pointed up into the exhaust pipe. but hey ill assume the steering shaft was in the way
Old Aug 21, 2012 | 08:04 PM
73AMC's Avatar
Hammered on the getting the wastegate routed. Was pissing me off so I just got mad at it and got it done.
DONE! Made if fit after the merge...
Old Aug 21, 2012 | 09:08 PM
LS1NOVA's Avatar
Next time you do one think of it like this. If possible, the exhaust gas should flow to the wastegate just as easy as the turbine. If you could have used a 90 right where it attaches to the merge it would have been much better but it should work as is seeing the setup isnt too crazy.
Old Aug 21, 2012 | 10:25 PM
Looks good to me, and I think that's the lesser of the two evils. obviously not ideal, but if you don't have the room you don't have the room.
Quick question though. What are you doing with the exhaust?
