this worth the money?
Old Aug 26, 2012 | 09:27 PM
ToxicWS6's Avatar
wiseco pistons are K392X3905
he lists the rods as "RPM H-beam connecting rods" but i cant find an ls1 rod listed as that specifically, any one know what it might be? spec wise just so i know exactly what it is
btw this is the link basically
"LS1 bottom end built for forced induction.
Wiesco inverted dome pistons (8.6:1 compression ratio with ls1 heads)
Only bottom end and block for sale
Engine is in the car and broken in so you can hear it run. No longer have the money to continue the turbo build i was doing."
