this worth the money?
Old Aug 22, 2012 | 08:40 PM
ToxicWS6's Avatar
Default this worth the money?
local guy is selling a broken in, still in car running short block (guess he pulls it when u buy it) ls1 with Wiesco inverted dome pistons and RPM H-beam connecting rods with stock crank, says its 8.6:1 CR with stock ls1 heads
he only wants $1400 for it, selling cause he ran out of funds for his turbo build, im looking to go turbo (85% there) but wasnt really planning on any engine mods or swaps for awhile, is this worth grabbing for $1400 and then holding on to it and throwing an EPP blower cam in it and a set of 243s possibly and installing in the near ish future when $$ is better?
how would 8.6:1 (i guess 9:1 CR if i use 243s (ls6 heads) be for a DD? and how much boost could i run safely and about how much power? would use ARP studs for heads and im running a BBK intake and 80mm TB
any input appreciated
Old Aug 22, 2012 | 09:15 PM
js2fst's Avatar
I would do it if you know who built it. Rods and pistons rings can cost and more than that
Old Aug 22, 2012 | 10:41 PM
Build-it-Break-it's Avatar
No thats a horrible Deal!! What's his number??!!
Old Aug 23, 2012 | 06:20 AM
got-a-ls1's Avatar
yea yea we need to call him and talk some "cents" into him....
Old Aug 23, 2012 | 09:18 AM
ToxicWS6's Avatar
Lolol if i can work some money around im probably gunna see if i can get it
Old Aug 23, 2012 | 09:24 AM
ToxicWS6's Avatar
How would this be for a DD car with that type of CR, and with forged rods and pistons what kinda hp/psi numbers are we thinkin
Old Aug 23, 2012 | 09:53 AM
96s-10ss's Avatar
If its actually 8.6:1 with forged h-beams, I wouldnt be afraid to throw 22-25psi to it with supporting mods. The hp numbers will be in your turbo selection/tune.
Old Aug 23, 2012 | 04:07 PM
ToxicWS6's Avatar
Ok thats what i was kinda wondering, if i dont get it ill let yall know for others that are interested
Is there a way to check the CR after i got it? Or have to be sent out
Old Aug 23, 2012 | 10:44 PM
96s-10ss's Avatar
Find the part number of the pistons, take a look, its in a book, reading rainbow. Compression ratio is determined by piston, head gasket and combustion chamber size.
Old Aug 24, 2012 | 12:36 AM
itsslow98's Avatar
Im 8.5:1 and id feel fine with 93+meth and 26lbs just gotta watch the timing. It wont be the most responsive down low with that compression but street driving is no issue.
Old Aug 24, 2012 | 02:19 AM
02anti_vnm's Avatar
I say go for it if the CR is to low for your comfort on a street car you can always mill the heads to bump it back up so it won't be as sluggish off boost. But granted you'll need to run less boost. It's all about your goals and how you want the car to drive. But I say go for it it's a good buy
Old Aug 24, 2012 | 07:09 AM
Preston99WS6's Avatar
Run it, if your worried about response on the street pick up a set of ON3TURBO twins fab it up and it will respond just fine. 2 of these turbos will support 1000+RWHP and can be had for the cost of the larger single unit. Sure you have to run two gates but the 38mm gates are pretty cheap from tial or turbosmart and are good.
Old Aug 24, 2012 | 11:04 AM
ToxicWS6's Avatar
https://ls1tech.com/forums/forced-in...ine-build.html
I made this right after as a seperate thread but
Old Aug 24, 2012 | 11:16 AM
98Z28CobraKiller's Avatar
Restricted User
I just wouldn't give him the money until I saw the short block and was able to see the bores and pistons.
Old Aug 24, 2012 | 11:41 AM
Burken01's Avatar
Get ready for a ride! Your parents, gf/wife, friends and pets are gonna hate you... Turbo builds are a bitch!
Old Aug 24, 2012 | 12:45 PM
^ This.
Old Aug 24, 2012 | 05:45 PM
HRHohio's Avatar
^ X2 !!!! But damn aren't they fun when they're done.
Old Aug 24, 2012 | 06:53 PM
ToxicWS6's Avatar
Lmaoim probqbly gunna go test drive the car with engine in it hear it run etc, give him $200 downpayment towards it to pull it out etc and he'll get the rest once i see the block and all and its in the back of the truck lol, gf already not to thrilled were going to look at the engine sat night lol
Any other suggestions when i go to look at it what to look for, fyi he was trying to sell the car with this engine as a whole about a year ago never turboed, from the sounds of it hes pulling out his built motor and putting a lq4 in ot so its more n/a driving friendly the a low CR n/a ls1
Old Aug 25, 2012 | 12:50 PM
LSX FOX's Avatar
hell yea thats worth it..if its a block, crank, bearings, rods, and pistons/rings..id deffinently get it..ls stuff isnt cheap at all, i just spent that on rebuilding my bottom end with new pistons(not forged).
Old Aug 26, 2012 | 09:17 PM
ToxicWS6's Avatar
well i went ahead and got it, guy is gunna pull it out and give me a call when its ready to pick up, i got the full short block and 243 heads for $1600, i havnt given him any money yet, full payment when i pick it up, ill let yall know how it is when i get it in my car and running
would you all feel the epp blower cam would be good with this engine or should i get a custom grind cam for this? thanks
