dyno #s
Old Apr 6, 2004 | 03:51 PM
99t66ls1's Avatar
Default dyno #s
Dynoed car for the first time 11 psi mix of 104 and pump gas, have ran the same amount on pump gas but and had no detonation but decided to mix just in case.
633 rwhp
629 rwtq
i was happy with the horsepower but disapointed in the torque any suggestions on the low torque numbers would be appreciated.
Attached is a scan of the dyno sheet
File Type: bmp
Old Apr 6, 2004 | 04:02 PM
MIGHTYMOUSE's Avatar
numbers look really good for that low boost. what is your head and cam set up?
are you seeing full boost before tq peak?
Old Apr 6, 2004 | 04:04 PM
cablebandit's Avatar
Forget about the "low" torque numbers. Look how nice your hp curve is!!!! I woulda KILLED for a flat curve like that with my TTi kit. Nice numbers!!!!!!!!!!
Old Apr 6, 2004 | 04:23 PM
99t66ls1's Avatar
heads are stock minus 918's cam is a 224 218 568 563 on 114
Old Apr 6, 2004 | 04:24 PM
Earl H's Avatar
633 rwhp
629 rwtq
When are you getting full boost? looks like about 4500-5000rpm. My PT76 GTS hits 12psi by 3300rpm. I just upgraded from a PT71 GTS a few weeks back and notice no increase in spool time. I haven't dyno'd yet with the bigger turbo, because I'm waiting for my 422 shortblock.
Old Apr 6, 2004 | 04:26 PM
eviltwins's Avatar
What exhaust A/R and exhaust wheel are you running? Checked for small vacuum leaks?
Old Apr 6, 2004 | 04:32 PM
99t66ls1's Avatar
i also have the t76 gts, and i dont see full boost until 4400 or so, check for vacumn leaks where, are you refering to spool time or to the peak tq numbers with the vacumn leak, the exhaust housing is a tangential .96 and exhaust is 3 inch with a bullet muffler
Old Apr 6, 2004 | 04:44 PM
MYTURBOT/A's Avatar
Little info on your setup please, wheres the turbo located? What kind of car? Very nice numbers!
Old Apr 6, 2004 | 04:47 PM
99t66ls1's Avatar
details and pictues were posted earlier i dont want to go over all of them again, look back and search for some of my previous posts, they have all the specifics and pictures
Old Apr 11, 2004 | 06:37 PM
99t66ls1's Avatar
ttt no suggestions on the lack or torque?
Old Apr 11, 2004 | 07:34 PM
RICE ETR's Avatar
Turbo Addict
Very nice numbers Chad!! So crank the boost up already!
Old Apr 11, 2004 | 09:37 PM
Got Me SOM's Avatar
there's nothing wrong with your torque numbers that's a nice smooth linear curve, most turbos have the serious spike in power, looks good on paper but really impractical on the street, ie major tire spin, and broken trannies.
i've made up my mind, my next ls1 will be a turbo, if i get a nice settlement, want to do a 427 TT.
Old Apr 12, 2004 | 12:28 AM
BIGBOS's Avatar
It would be interesting to see what it does with about 17-18lbs
Old Apr 12, 2004 | 06:08 AM
smokinHawk's Avatar
torque is ok, but reason its probably lower becasue your full boost comes on so late.
thats why a turbo will make more torque then a supercharger becasue you hit full boost sooner.
its very strange that you dont hit 11psi till 4400rpm. my restrictive TTi kit gets 10psi at 2900rpm through full exhaust and 2750rpm when the cutout is open.
and your exhaust path is shorter then the tech kit.
id definatly look for leaks.
what intercooler are you using?
Old Apr 12, 2004 | 09:58 PM
99t66ls1's Avatar
I am using a custom intercooler it is a 1000 horse core that we built the endtanks on, one reason for the possible slow boost time is that the car unfortunately has 4:10 gears and does not allow enough time to build the boost, i will be switching gears this week hopefully that will help.
Old Apr 13, 2004 | 01:15 AM
BIGBOS's Avatar
Stepping down to 3.73's?
Old Apr 13, 2004 | 08:33 PM
99t66ls1's Avatar
3.23s looking to the future and more power
Old Apr 14, 2004 | 01:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Big exhaust housing?
When I see big torque numbers I tend to generalize and regard that setup as having too restrictive of an exhaust, downpipe, etc.
