ASP Cogs?
Old Apr 6, 2004 | 10:06 PM
BlackNite383's Avatar
Default ASP Cogs?
How much boost are the ASP cogs supposed to make with a D1SC at 6,000rpm? Do they offer different boost levels? I'm looking to make about 14psi, so just wanted to know if the cogs will spin the blower to that speed.
Den
Old Apr 6, 2004 | 11:29 PM
scottywheels's Avatar
asp made my 8.5 8 rib and I run a riechard racing blower pulley and I have no slip at 15 psi. I dont know why everyone is going to cogs, my 8 rib works awesome.
Old Apr 7, 2004 | 12:49 AM
BIGBOS's Avatar
Scott, I think the main reason yours worked and my ASP didn't was because of mine being quite a bit smaller, its 7.85", I was having really bad slipping problems with a 3.3" RR pulley......everything was alinged perfect, and had max tension on the belt, held 14psi, then nosedived, so if maybe you make the tensioner slot lower you can run even more tension, but thats got to be hard on the front of that setup........
I'm running the ASP COG setup right now, its a 73/31 tooth setup, its going to max out the D-1SC probably at 6500 rpms, I think it should make about 15-16psi at that level....You have to make the slot in your bracket where the tensioner runs opened up 1.25" so you can slide the belt on under the tensioner......so far so good this way.....
I'm having problems keeping my crank bolt in, thats because it was used 4 times previous, so I ordered a new one, and this should hopefully do the job......
Just flashing the converter in 3rd gear, it goes to 6-7psi and blows off, I'm sure its going to make some boost......HOPEFULLY
Old Apr 7, 2004 | 04:07 AM
HUGGER ORANGE SS's Avatar
I did my tooth count..
I'm running 72 Crank and 30 Blower. I'm seeing a max of 11psi at 6400 rpms.
Scott ws6. I'm glad your not having slippage issues. But I do believe thats because you don't half to spin your F1 as hard as our P1 or D1's With your internal step up ratio of 5 to 1 VS our 4.10 to 1 does make a difference.
To see my numbers I had to go COGS. I believe I'm the only one whos making the ASP cosgs setup work so far.. I've had mine for over 1 year, and my only problem is a break my cogs belts from time to time.
Clint
Old Apr 7, 2004 | 02:38 PM
BIGBOS's Avatar
I'll get mine to work as well here shortly hopefully
Old Apr 7, 2004 | 11:26 PM
hugger im spinning the blower at 68k I just happen to have a 5 psi drop with the stock innercoolers. I will be making 20 psi soon as the fmic is done...
Old Apr 8, 2004 | 12:02 AM
NA$TY-TA's Avatar
Damn.. a 5 PSI drop thru the intercoolers??? how do you know thats how much you are loosing Scott?
What FMIC you going with?
Kyle
Old Apr 8, 2004 | 10:43 AM
20psi on your setup Scott WS6 would be scary!!! 20psi would be scary anyway.
Clint
Old Apr 8, 2004 | 04:03 PM
BIGBOS's Avatar
I bet I will max out those little intercoolers too.......he is using the same FMIC that PSJ has, I plan on using this too this fall if I get the currently setup consistent
