WS6 LS3 Whipple
Secondly would be figuring out where to put a water tank/pump in an already cramped car.
Any tech or comments would be appreciated, Thanks.
I have done plenty of this and don't want to dig old threads that got a lot of people butt hurt on screws for F bodys'. So please move forward here this is Tech related and anything is possible given better pros vs' cons. Trending Topics
I can't find any info on it because every time I find a thread about it it ends with someone saying "do a search". What good does doing a search do you when every thread you search for tells you to do a search and go elsewhere
Anyway, I'm seriously interested in putting a twin screw on my T/A. I know Hawks sells a Magnuson kit, Whipple has a kit for F-bodies on their website, also I've heard about Kenne Bells but haven't actually seen a kit yet. Sure prochargers and turbos are great but neither really have that "wow" effect for me when you open the hood like a good twin screw has. Let's keep this thread going guys! d love to hear more on this. Any companies making these kits, any way to piece them together to keep the price down, just any and all info would be great
PS: my T/A is a 2000 built by the previous owner for a D1SC that never happened. Has full LS6 swap out if a CTS-V, TruTorq lvl 5 cam (I know it's hard to find info on the level 5 especially in anything smaller than a 6.2 so let me know if you have questions), Pacesetter headers, locking header bolts, SLP LS6 intake, 243 heads worked over by Texas Speed, Patriot Gold valve springs, BBK 80MM TB, SLP smooth bellow, Z06 MAF, off-road 3" Y-pipe, 3.73 gears, UMI subframe connectors and traction bars. Might be forgetting some. Thanks
So in order to drop the motor a solid 3", you need to go to a dry sump setup so you can get a very shallow oil pan. Next you'll need custom k-member and engine mounts. Once you do that, you are on your way to roasting your tires are part throttle at 1500rpm.
Is it the way they sound, or how they look under the hood? It can't be that it's faster than a turbo or centri-blower because I don't see any of the fastest c6s or 2010+ camaros running big positive displacement blowers. Sure they make a **** ton of torque down low, but all that does is haze the tires instantly.
As Alchemist has pointed out, it will be less efficient although still fun to drive.
If your planning on running any good times at a track, dollar per dollar, you'd be wasting money.
The road less traveled will be very interesting to witness however. The task at hand is more about making it a clean install though.
Anyone can hack it to bits and make it fit for you, but few can make it look like it came that way without using a blower so small that it only makes 500hp. They are essentially big heat sponges in my experience. I have a supercharged Cadillac with one, and it really is fun as a DD because of the torque at low rpm, and the minimal effort it takes to get it moving. However even at 15lbs it really does not build that much after the hit, and sort of falls on its face especially in summer months. For A DD street car, a Whipple would be nice.
