Simple combo-big power-347+D1SC=800+rwhp
Old Sep 8, 2012 | 07:08 PM
cause4panic's Avatar
Does not compute.... Error 404
Old Sep 8, 2012 | 07:24 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
With a 3.55 head unit pulley, it depends on how big the crank pulley is. I think he uses one that is close to 8" if memory serves me correctly.
If that's the case, it would be (8/3.55) *4.10 internal stepup *7000rpm = 64676 blower rpm. Max impeller rpm for a D1SC is 62,000.
I'm sure the original poster can comment. I think this was a corvette, not sure.
Old Sep 8, 2012 | 07:45 PM
I8UR4RD's Avatar
It is def an interesting result. But there are some freaks out there. that just simply make the power.
Old Sep 9, 2012 | 07:46 PM
What size are your injectors? What meth nozzle are you using?
Old Sep 9, 2012 | 08:04 PM
eb02z06's Avatar
Originally Posted by 98cobra
Just curious. How are you getting 800 horsepower out of a D1SC, without even maxing it out? Not flaming you. Just curious
800 rwhp out of a D1SC on a LS motor is not uncommon. I'm pretty sure there are plenty out there.
The pulley combo is a 3.55 with a 8" crank-for a impellar rpm of 64k-but given 5-10% belt slip it's probaby only turning 60k.
About 6 years ago I made similar power through an auto on my car-it's a very capable blower.
Old Sep 9, 2012 | 08:06 PM
eb02z06's Avatar
60lb injectors with twin #15 nozzles with an Alky Control kit.
Old Sep 17, 2012 | 04:55 PM
Red Baron's Avatar
30gph is a lot of meth isn't it?
Old Sep 17, 2012 | 06:51 PM
eb02z06's Avatar
25gph is the standard deal on the Alky setup, 30gph is not uncommon.
Old Sep 17, 2012 | 07:18 PM
allout06's Avatar
damn....i was gonna go with an AES motor, but this has me rethinking. itd probably be cheaper to stay with my motor and buy a rotating assembly. i wanna make like 850rwhp. Id probably move up to the F1A though. What are you thoughts on this? 347/F1A. im just worried about lifting a head or pushing water. thats why i was just gonna go bigger cubes with a bigger blower but still only make moderate boost and big power vs small cubes/high boost.
what kind of fuel system also.
Old Sep 18, 2012 | 08:05 AM
Ballzee's Avatar
D1's FTW!!!!!!
Old Sep 18, 2012 | 09:42 AM
eb02z06's Avatar
It's running a Lonnies double pumper setup. I have never had any water pushing issues with 4 bolt heads and 1000 rwhp.
The F1A is a badass little blower.
Old Sep 18, 2012 | 04:42 PM
  #32
allout06's Avatar
waht would you do if u had the options?
Old Sep 18, 2012 | 05:51 PM
  #33
BOBS99SS's Avatar
Captain Double Post
That is just sick,who says you cant go fast on a budget
Old Sep 18, 2012 | 11:13 PM
  #34
fastcars95's Avatar
Thats got to be close to the limit of 60lb injectors. Are you worried about the meth going down and losing all that fuel.
Old Sep 19, 2012 | 03:16 AM
  #35
Wildside's Avatar
Done we did 886 347 ported 317 done buy my shop cheater cam f1a 18 psi meath and a 75 shot of dope. Not done yet going up with the boost aging
Old Sep 19, 2012 | 09:24 AM
  #36
eb02z06's Avatar
I'll check the log but I think we were in the 85-88% range. No fear of having the meth fail-this is what happened when it did earlier this year.
http://youtu.be/chkL2LLoE8c
As the IAT's rise the timing drops and more fuel is added-this is the safeguard I build into every tune.
Old Sep 19, 2012 | 06:19 PM
  #37
T/A KID's Avatar
EB thats how I do it now too.
In PE mode I use the IAT table to add fuel with increased temps and I pull timing. Even if you were to max out the injectors with the increase in IAT's (adding fuel) the IAT spark table would make it safe if pulling timing.
I will say this though, I use to be a big fan of spraying 100% meth but on my kit I sprayed 100% meth with twin 14gph nozzles and it would change the AFR 2 full points. I am back to 50/50 mix and the change is roughly 1 full point.
Old Feb 11, 2014 | 11:39 PM
  #38
CAMSTER's Avatar
60 lbs. injectors can help make a lot of power if you have the fuel delivery to back them up, I have made over 1,100 super charged crank torq at 80 % cycle using 60 lbs. injectors and my friend watching there asked me how was possible if he was running out of injector duty cycle at 650 whp my answer-get a good fuel delivery to support your injectors.
When your fuel delivery lacks the injectors have to make up so the tuner adds duty cycle till it maxes out then tuner can no longer add fuel, at that time must will ran out to buy bigger injectors, in must cases this is wrong-upgrade your fuel delivery system.
Old Feb 12, 2014 | 01:50 AM
  #39
fotoboy's Avatar
F1d w a 346. I made 817 and 788 wtq. This all below 6000 rpm. Congrats on combo.
Old Feb 12, 2014 | 07:11 AM
  #40
UNDER PRESSURE MOD
I still say it's hard to beat a D1SC for a street car.
