Audi S4 getting american blood... *some pics*
#42
New melling oil pump on. More transmission parts are here as well including the ck rmvb (non tb). Need to sell my cummins so i can finish this up. I got a 01 silverado for a towpig as well, so the 2wd cummins wont be missed , altho it was pretty fast in its hayday (13.6@106/2.5 60').
#46
Updated plans:
Lr4 4.8 90k miles (untouched ring gap)
Pac 1218s
Ljms stage 2 turbo 226/231 cam
New pushrods
Melling oil pump
Ebay head studs
Ebay front sump sheetmetal oil pan
Ls1 intake manifold
Stock truck dbc tb
Flipped/chopped/cut/vband truck manifolds
Full power steering & a/c
551494-3 pass/high a/c bracket for sanden 508
551521-3 driver/high alt & ps bracket
Twin t3 60mm hx40w w/ internal wastegates
Dual in/single out intetcooler
Dual knockoff tial bovs
Ls3 water pump, straight therm outlet - undecided
80lb dekas @ 75psi base
Dual intank 450s
-8an feed/-6an return
3bar/flex fuel/dbc p59 savanna ecu
Gm flex fuel sensor
3bar gm map
Th400
Ck performance rmvb
Rollerized billet fwd drum
34element sprag
Dual feed
Green clutches
Freakshow converter (~3800stall)
Stock rear end (3.10) w/ reinforced case
Custom 'phantom grip'-like lsd or just welded spiders
Stock 18" avus wheels
265/40/18 m/t et street (r)
Goals: 9.9x 1/4, 750+whp (uncorrected), 20+mpg e85/ 25+mpg 91, flex fuel, a/c, full interior
Pac 1218s
New pushrods
Melling oil pump
Ebay head studs
Ls1 intake manifold
Stock truck dbc tb
Dual intank 450s
Gm flex fuel sensor
3bar gm map
Th400
Ck performance rmvb
34element sprag
Dual feed
Green clutches
Love all of this.
you know your an OG import guy when "Phantom grip" brings back great memories...LOL
#47
Haha, yea. ColtB, i love your fc. See that u used to have 4g fc. Actually i had a built 2.3/kelford 280 4g that i was thinking of throwing in this audi first. Had the bill hutcner(sp?) Adapter kit and everything. Ended up selling it to my buddy
#48
#58
sorry for lack of updates, havent been on tech in a while. Build is coming along nicely. Engine and trans are in, shift linkage in, wiring harness and ecu is in, fuel system is in, turbos are on. Should have it mobile in a few weeks
