T brake, drag radial guys.how so you do it?
So I was a first time tbrake user and first time drag radial yesterday. Could not get it to hook at all.
Track prep was good,i tried leaving at 8psi,wot and it was up in smoke.
Same on 5psi. I ended up just foot braking it to a 10.1 @137. 1.585 60ft.
I'm running a 275 60 15 bfg drag radial with 13psi in them.
Qa1 set all the way loose in the front,on click 7 in the rear. Pinion angle at minus 2. 3790lb race weight.
Thanks
Alex
Thanks
Alex
My pressure is at 17-18. Post a vid of what its doing. It takes time there are so many variables. Rpm, boost, shocks, pressure, instant center ect.
I could never get the trans brake to work until i raised my instant center. Once i got that and the shocks, bam itll hook in wet grass
